Has anyone expercience with tapping of crurrent from the power regulator on the Aruino Mega board. According to the specs, this power regulator can deliver 800mA. I need 360mA to feed a LED strand of 9 leds (=9 x 60mA max). That would leave enough romm for the basic Arduino Mega functionalities. I would do this for a clean installation.
The powerr supply would come from the USB port or the power jack, I have the choice. What would you prefer? The specs of the power source are 5V with around 2700mAh.
Kind regards,
Luc
Tapping current from the voltage regulator of the Arduino Me
Re: Tapping current from the voltage regulator of the Arduin
You need a 7-12v power supply if you want to use the DC power jack. The regulator needs a couple volts of headroom to work. If you decide to do that, the 'Vin' pin from the 'POWER' header bypasses the 5v regulator and gives you a direct connection to the power supply.
If you power the Arduino from a USB cable, the '5v' pin will give you a connection to that supply.
For more information, you can look at the Mega specifications on the Arduino website under the 'Power' heading: http://arduino.cc/en/Main/arduinoBoardMega
