Motor controller dc with trinket
Re: Motor controller dc with trinket
The Trinket can take up to 16V on the BAT+ pin. If you connect power to the USB+ pin, it must be 5v only.
- emcma002
Hello, I recently purchased a trinket 5v and 3.3v. I am trying to use it to control a dc motor with a potentiometer. could you please help me with the code that i need to do this with? that would be greatly appreciated!
Please post a link to the electrical specifications for the motor you want to drive.
Also, what kind of control do you need? Speed only? Or direction and speed?
- emcma002
I need just speed control and the specifications for the motor are: 12VDC motor
12v DC motors come in many sized and have a wide range of current requirements. We'll need a bit more detail than that.
- emcma002
Brand new motor manufactured by Nichibo
Model UC-280P-19160
Operates on 12 VDC nominal
Operating voltage range: 6 VDC to 12 VDC
No load speed at 12 VDC: 11,500 RPM
No load current: 150 mA
Full load (maximum efficiency @ 12 VDC) performance characteristics:
Speed: 9,000 RPM
Current: 570 mA
Torque: 46 g-cm (4.51 mN-m)
Power output: 4.3 Watts
Stall torque: 250 g-cm (24.51 mN-m)
Stall current: 2,900 mA
Model UC-280P-19160
Speed: 9,000 RPM
Current: 570 mA
That is a relatively small motor, so a small transistor like a PN2222 will be sufficient to drive it. You can use the circuit and code here, with the Trinket substitued for the Arduino.:
https://learn.adafruit.com/adafruit-ard ... ransistors
Also, you will need to use pin #0 or pin #1 on the Trinket instead of pin D3 on the Arduino.
The code will be the same as the Arduino code in that tutorial also - except you will need to change "motorPin" to the pin number you are using on the Trinket.
https://learn.adafruit.com/adafruit-ard ... duino-code
- emcma002
How would i go about adding a potentiometer to the circuit?
See the potentiometer wiring in this guide:
https://learn.adafruit.com/trinket-gemm ... rol/wiring
