Hi all. I'm extremely green with this, please forgive my ignorance. I've been tasked with making LED's flash around the sole of a shoe for a performer. the soles have been hollowed out and 24 holes drilled to fit the 10mm diffused white LED. Can you please suggest a device/battery combo and wiring method (serial or parallel) to make this work. the insole will be removable from the shoe to access the battery pack and device in the heel area to turn it on and off but once i last the upper to the sole, there will be no access for maintenance to the LEDs. I have 1.25"w X 3"l X 1"d to work with.
thanks
john
Need to make LED's flash
Re: Need to make LED's flash
- Attachments
- image.jpg (39.94 KiB) Viewed 993 times
Yes, i have. I've modified a version of this for the shoes i had to make using the color strips (HC-F5V-60L-60LED). For the current pair of shoes, i have the Litex white (1398) worked into the upper of the shoe running independently using the included controller. in this instance, I need to stick with white in the sole and give them the option of running solid or flashing. Is there a way to use the Flora to just flash using only the 2 wires for the white LEDs? i've tried a device from Radio Shack, a battery powered inverter (2760338) but it seems to throw out some extremely high voltages that appear to be killing some of the LEDs.
For simple flashing you could use a Flora (or Gemma) and one pin to drive the LEDs via a MOSFET. You would need to wire the LEDs in parallel. With a 3.7v LiPo cell for power and white LEDs, you would want to use a current limiting resistor of about 12-15 ohms in series with each LED.
Thank you very much for this, this sounds like a perfect solution. Is it possible for me to contact the order desk and have someone help me put together an order with will have everything i'll need?
Here is a list. We don't stock the resistors, but they are available from most any online electronic parts supplier (Mouser, DigiKey, etc).
Qty for two shoes:
2x Flora http://www.adafruit.com/products/659
2x 500mA LiPo cell: http://www.adafruit.com/products/1578
2x Micro LiPo USB Charger
2x Pkg 25 10mm white LED - http://www.adafruit.com/products/846
2x N-channel MOSFET http://www.adafruit.com/products/355
You will also need 48x 15 ohm resistors and some hookup wire. I assume you have soldering supplies. For hookup wire, I would recommend small gauge (22-24) stranded wire for flexibility.
Qty for two shoes:
Thank you very much. I'll log on and take care of this. I do have the soldering hardware, i'll start looking for the other parts.
Will i need to create a program for the Flora (i warned you, i'm green) or will the flashing happen by default by powering it up and using the listed parts?
Naturally, i'm in a time crunch and right now i don't think i'll be able to figure out the language quickly. if a program is needed, is there someone thru your company or that you can refer me to for contracting out the programming on short notice?
thanks
john
thanks
john
There is a test program loaded by default. But it is not very interesting (1 second on, one second off). So you will probably want to customize it. If this is not your area of expertise and you would rather farm it out, you can post it in the "Contracts" area of our Jobs board: http://adafruit.com/jobs/
Thank you, i'll head over there.
john
john
