I want to use this display adafruit/ST7565-LCD but where are the AVR-GCC libraries that the site is mentioning below?
also the site is saying that they are the same for GCC and Arduino but its not true since the library that is there is using the "shiftout" function which does not exist in AVR-GCC.
thanks
There are two 'versions' of the LCD library - one is straightup avr-gcc and the other is an Arduino Library. They're essentially the same. You can create new icons for bitmapdisplaying using bmp2glcd have fun! limor
http://www.ladyada.net/learn/lcd/st7565.html
adafruit/ST7565-LCD
Re: adafruit/ST7565-LCD
The code lives in our Github repo, which is linked from the page you mentioned: https://github.com/adafruit/ST7565-LCD
hi Mike !
I have the code you mentioned already , what I am saying is that that code has only one library and that's for arduino , where is the code for AVR ?
thanks
thanks
- Franklin97355
I would think if you want AVR-GCC specific code you will need to write it although there may be some out there someplace if you look (Google?)
