Adding FRAM to Arduino Micro ?
- solardude
Hi, I am wanting to add FRAM if possible to the Arduino Micro board so I will have enough memory to run the larger 128x128 & 400x240 pixel Sharp Memory Displays that require 2-12,000 byes of memory to buffer the screen image.
I found this and I think it should work but I would prefer the benifits of a FRAM chip instead if possible. Would both options require the same code that you supply for this 1 Mb memory chip? http://www.adafruit.com/products/1564
Re: Adding FRAM to Arduino Micro ?
Every chip has its own interface for communication. You'd need a library that can talk to whatever chip you select.
