Hi!! I'm very busy and running close to my deadline. I'm not very good at programming.
Can somebody please please pleeease, put together a code for me, or any kind of help!!! My strip light is the latest neopixel 60LED strip light 3m long.
I need the strip light to be WHITE and have a slow up and down movement down the strip
ANY HELP is GREATLY APPRECIATED!!!!!
URGENT!! Help with programming neopixel strip!!!
- brucef
Re: URGENT!! Help with programming neopixel strip!!!
Maybe what you're looking for is a Larson scanner?
To change the red to white in that code, you need to turn on the red green and blue subpixels, rather than just the red ones. E.g. change:
to:
The center one is a bit tricky if you don't understand the hex, so I'll give you that one too; 0xFFFFFF should do what you want.
strip.setPixelColor(pos - 2, 0x100000); // Dark red
strip.setPixelColor(pos - 2, 0x101010); // Dim white
Awesome!!! Thank you so much, it worked like a charm!!
Ok, how can I slow it down a little bit?
- brucef
Glad it worked! As for speed, play with this line:
That number is an approximate number of milliseconds, as documented in the Arduino reference.
delay(30);
