I'm running a 4WD robot using the AF Motor Shield v1. I put slave code on the robot, and drive it from master code on a remote control I build on a bread board (4 buttons, 4 directions). It's pretty simple. When I push the left button, left wheels go in reverse, and right wheels go forward. So the robot turns in place when instructed to.
What I'd like to do is create a differential drive for the robot. So when I press the left button, the left wheels will not spin in reverse, but will spin forward at, for example, 50% those of the right wheels. Actually, I need to be able to alter the PWM as needed.
There are a few ways I have thought to do this, but nothing seems to work.
In the code, I want to alter the FULL CODE (shown at the bottom of this question) to be:
// TURN LEFT
void Left_Turn(void)
Serial1.println("LEFT TURN");
// front wheels
Motor_Left_Front.run(FORWARD*0.5);
Motor_Right_Front.run(FORWARD);
// rear wheels
Motor_Left_Rear.run(FORWARD*0.5);
Motor_Right_Rear.run(FORWARD);
delay(10);
So I also tried to introduce 'double x' for % of speed and similar to 'double y' in the FULL CODE, where x and y are decimals between 0-1. But this does not seem to work either.
(You can see what I'm trying to do in the FULL CODE, void loop() part, under ' else if (incomingByte == 'L') // spin LEFT'.)
// TURN LEFT
// front wheels
Motor_Left_Front.run(pwm*x);
Motor_Right_Front.run(pwm*y);
// rear wheels
Motor_Left_Rear.run(pwm*x);
Motor_Right_Rear.run(pwm*y);
delay(10);
Below is the FULL CODE that does work (variables are set to type 'double', but initially I used type 'int' and it worked too), but it does not contain any PWM modifications as I would like. Is there a simple solution to what I'm trying to do?
#include <AFMotor.h> // AF Motor shield library
const double speed = 100; // percent of maximum speed
double x = 1; // start x at 100% of speed, but doesn't seem to work
double y = 1; // start y at 100% of speed, but doesn't seem to work
double pwm;
int incomingByte; // a variable to read incoming serial data into
bool value = false; // set variable once for RC signal received
// define wheels (individual)
// front wheels
AF_DCMotor Motor_Left_Front(4, MOTOR34_1KHZ); // motor 4
AF_DCMotor Motor_Right_Front(3, MOTOR34_1KHZ); // motor 3
// rear wheels
AF_DCMotor Motor_Left_Rear(1, MOTOR12_64KHZ); // motor 1
AF_DCMotor Motor_Right_Rear(2, MOTOR12_64KHZ); // motor 2
//*****MOTOR FUNCTIONS
// Forward, Backward, Release
void Drive_State(int DRIVE_STATE)
if (DRIVE_STATE == FORWARD)
{Serial1.println("FORWARD");}
else if (DRIVE_STATE == BACKWARD)
{Serial1.println("BACKWARD");}
else
{Serial1.println("RELEASE");}
// front wheels
Motor_Left_Front.run(DRIVE_STATE);
Motor_Right_Front.run(DRIVE_STATE);
// rear wheels
Motor_Left_Rear.run(DRIVE_STATE);
Motor_Right_Rear.run(DRIVE_STATE);
delay(10);
// TURN LEFT
// front wheels
Motor_Left_Front.run(BACKWARD);
// rear wheels
Motor_Left_Rear.run(BACKWARD);
delay(10);
// TURN RIGHT
void Right_Turn(void)
Serial1.println("RIGHT TURN");
// front wheels
Motor_Left_Front.run(FORWARD);
Motor_Right_Front.run(BACKWARD);
// rear wheels
Motor_Left_Rear.run(FORWARD);
Motor_Right_Rear.run(BACKWARD);
delay(10);
void setup()
Serial1.begin(9600); // set up Serial library at 9600 bps
// scale percent into pwm range
pwm = map(speed, 0, 100, 0, 255); // takes range of 0-255 and maps it to 0-100 for variable 'speed'
// actual pwm value is define as const at beginning of code
// front wheels
Motor_Left_Front.setSpeed(pwm);
Motor_Right_Front.setSpeed(pwm);
// rear wheels
Motor_Left_Rear.setSpeed(pwm);
Motor_Right_Rear.setSpeed(pwm);
void loop()
if (Serial1.available() > 0) // see if there's incoming serial data:
incomingByte = Serial1.read(); // read the oldest byte in the serial buffer:
value = true;
if (incomingByte == 'F') // FORWARD
Drive_State(FORWARD); // forward
else if (incomingByte == 'B') // BACKWARD
Drive_State(BACKWARD); // backward
x = 0.7; // turn left wheels 70% speed of right
Left_Turn();
else if (incomingByte == 'R') // spin RIGHT
y = 0.7; // turn right wheels 70% speed of left
Right_Turn();
else
if (value == true) // done so not always pinging motors
Drive_State(RELEASE); // stop
// x = y = 1; // set pwm back to 255
value = false;
