I'd like to add a compass (https://learn.adafruit.com/adafruit-hmc ... g-and-test) to my robot. My robot will use:
- Ultimate GPS Sheild
- Arduino Wireless SD Shield
- Arduino Leonardo
- 2 sonar sensors (http://users.ece.utexas.edu/~valvano/Da ... CSR04b.pdf)
Now i'd like to add the compass from the first link. My concern is that on the page it says, "The HMC5883L has a fixed I2C address, you can only connect one sensor per microcontroller!"
Does this mean that I can't use any other sensors OR devices which use I2C? Or does it mean I can only use 1 compass sensor because the addresses are all the same for the COMPASS?
My understanding is that you can have many devices used on a microcontroller over I2C.
I2C connections
- egutting
Re: I2C connections
It means that you can only have 1 type of that sensor on your bus. There is a limit though on how many sensors you can have on 1 bus. If I'm counting right, you should be ok with those 5 sensors assuming none of them have the same I2C address.
- adafruit_support_bill
Re: I2C connections
Only one compass. You can have as many other devices on the i2c bus as you like - provided that they all have different i2c addresses.Does this mean that I can't use any other sensors OR devices which use I2C? Or does it mean I can only use 1 compass sensor because the addresses are all the same for the COMPASS?
