Setting gain/ranges on 9-DOF IMU with new _U drivers?
For Adafruit customers who seek help with microcontrollers
Adrian_Land
Post by Adrian_Land »
I'd like to use the 9DOF IMU as the heart of an Arduino inertial navigation system for my model planes. The rate of turn of the models requires using the higher ranges of both the accelerometer and the gyro. On this forum I've found your guidance for making these changes with the original Adafruit_L3GD20.h and Adafruit_LSM303.h libraries, but I've had no joy with the updated _U libraries.
Any guidance would be much appreciated. (I'm a novice programmer, so please 'scale' advice accordingly!)
Regards
Adrian Land
adafruit_support_mike
Re: Setting gain/ranges on 9-DOF IMU with new _U drivers?
The unified driver for the LSM303 has a function named 'setMagGain()' and a list of constants from lines 94-103 of the header file:
https://github.com/adafruit/Adafruit_LS ... LSM303_U.h
To set the LSM303 to its +/-8.1g setting, you'd use something like this:
    mag.setMagGain( LSM303_MAGGAIN_8_1 );
The unified library for the L3GD20 takes the gain setting as an argument to the 'begin()' method:
    gyro.begin( GYRO_RANGE_2000DPS );
The constants there are defined on lines 77-82 of the header file:
https://github.com/adafruit/Adafruit_L3 ... L3GD20_U.h
Adrian_Land
Hello Mike, thanks for the prompt reply.
The pointer for the gyro settings on the L3GD20 looks good.
Unfortunately, setMagGain for the LSM303 only looks at the magnetometer range settings (gauss), not the accelerometer ranges (+/- 2, 4, 8, 16g; see data sheet P.9). Guidance on how to set the accelerometer ranges would be much appreciated.
Best,
Adrian Land
Hmm.. that wasn't included in the library.
Attached is a modified version of the library that adds a function named setGain() to the accelerometer class. The options are:
    LSM303_ACCELGAIN_02                        = 0x00,  // +/- 2G
    LSM303_ACCELGAIN_04                        = 0x10,  // +/- 4G
    LSM303_ACCELGAIN_08                        = 0x20,  // +/- 8G
    LSM303_ACCELGAIN_16                        = 0x30,  // +/- 16G
and the line you want will look something like:
    accel.setGain( LSM303_ACCELGAIN_16 );
Give it a try and see how it works.
Adafruit_LSM303DLHC.zip
(75.37 KiB) Downloaded 76 times
Adrian_Land
Hello Mike,
Many thanks for the great support - very much appreciated! I've just had a quick check and your updates look good. I did remember to change:
static float _lsm303Accel_MG_LSB = 0.012F; // 1, 2, 4 or 12 mg per lsb
in Adafruit_LSM303_U.cpp to match the new gain!
Best,
Adrian
Cool.. it's always nice when code I couldn't test on the actual hardware does what it should. ;-)
Happy hacking!
Return to “Microcontrollers”
