Hi
I want to purchase the 24 channel 12 bit PWM led driver and the 12 channel 12 bit PWM led driver.
I got already the library for the 24 channel led driver.
I want to know if the 2 drivers can work together even with different number of channels?
If yes what do I need to change in the library so it works for this setup?
With kind regards
Question about the 24 channel and 12 channel led driver and
- daanm
- adafruit_support_bill
Re: Question about the 24 channel and 12 channel led driver
You can use both in the same system. But you can't chain them directly together. You need to load both libraries and use separate pins for connections.
- chris188
Hi, I search for the 24 Channel 12 bit PWM LED driver schematic. How can I get it?
Thank you very much in advance.
Eagle files for both boards are in Github:
https://github.com/adafruit/Adafruit-TLC5947-PCB
https://github.com/adafruit/Adafruit-TL ... eakout-PCB
