Hi team,
I had purchased the ads 1115 for 16 bit adc so that I can read voltage changes with a precision of 0.1875 mv.
The problem I am facing is that it is giving fluctuating results, ie differential example given on your website that shows the actual differential voltage ,is showing the results with inaccuracy of 8 mv.
eg if am giving constant 1 v to the A0 and A1 pin and observing results on the serial monitor of arduino, I am getting values betweeen 0.996 to 1.008 v fluctuating. On the other hand my multimeter shows constant 1.001 volts repeatedly without any error.
I am working on projects where these mv’s are very significant .
Can you suggest me a solution to this. Or any better product you sell that can sort my problem?
Fluctuating output ads1115
- adafruit_support_bill
Re: Fluctuating output ads1115
Your multimeter is taking an average of many readings over time (500mS is typical). This is effectively a low-pass noise filter. You should be able to achieve similar results using the same technique with the ADS1115. If you want to eliminate the noise at the source, you need to understand where it is coming from. A good place to start is by putting an oscilloscope on your signal and having a look at the nature of the noise.
