I am trying to use this backpack with a generic 16x2 LCD in my uController class. I'm trying to interface this with a 68HC11 using ASM11 assembly. Can I get more information on how to make this backpack work with assembly programming.
Nik
LCD I2C backpack
Re: LCD I2C backpack
This tutorial page has links to the libraries we use for the Arduino:
https://learn.adafruit.com/i2c-spi-lcd- ... /downloads
You can use them as working design reference.
In general terms, you'll need to decide whether you want to communicate with the MCP23008 using I2C or SPI, write code to support that communication, then handle control of the LCD through that interface.
- nerdcore
I2C is the bus I'm using as per the thread title. Also the library is in C. I need Assmebly.
We don't have any assembly code for that library or device, but like I said, you can use the C code as a design reference. It will show you what signals need to be generated and in what order.
Your first step will be to build an I2C interface, so start by reading the I2C spec and the datasheet for the chip you want to program. It may have its own I2C hardware, or you might need to bit-bang the protocol.
http://www.nxp.com/documents/user_manual/UM10204.pdf
