Hi I recently bought a teensy 3.1 and while soldering the headers some solder got on the processor pins.
I am not really sure what to do about this, If i need a replacement would it be possible to get teensy with the headers pre-soldered, if i need a replacement?
messed soldering teensy 3.1 headers
Re: messed soldering teensy 3.1 headers
Post a photo showing the problem. We may be able to suggest a remedy.
We do not offer assembly, but you may find someone here on the forums or at a local hacker space that could help you out with the soldering.
- chrs2021
Ugh, well I am pretty sure this is not in a fixable state. I don't feel like hunting down a hacker space to simply have the headers installed. I'll just go check out ebay, thank you for the quick reply.
- IMG_20141213_104030.JPG (715.81 KiB) Viewed 597 times
Yikes! It looks like all the pins on one side are bridged. You could probably clean that up with some solder-wick or a solder-sucker. Work a small section at a time and give it a chance to cool off a bit every few pins so you don't overheat the processor.
I just checked the PJRC store and they do have a pre-soldered Teensy 3.1: https://www.pjrc.com/store/teensy31_pins.html
- chrs2021
Already bought one on eBay that's local to me. Thank you again for the awesome support!
