Greetings,
I recently purchased the Adafruit Sous Vide kit http://www.adafruit.com/products/1401. I have built the hardware but have been unable to get the code (I am using the code from the Adafruit website) to compile as there are errors with the commands for the temperature controller. I have gotten the fewest errors using an older version of the Dallas Temperature Control Library (TLC 3.6.0) from http://www.milesburton.com/?title=Dalla ... .2FLibrary. With this library, I still get the errors:
PID_Controller.ino: In function 'void setup()':
PID_Controller:172: error: 'class DallasTemperature' has no member named 'setWaitForConversion'
PID_Controller.ino: In function 'void DoControl()':
PID_Controller:565: error: 'class DallasTemperature' has no member named 'isConversionAvailable'
Is there a certain version of this library that I should be using? Any modifications I should make to the code?
Thank you for your time!
Sous Vide Controller: Issue with Code/Dallas Temperature Lib
- GratefulDread
Re: Sous Vide Controller: Issue with Code/Dallas Temperature
The code for the tutorial was compiled with the latest version which is 3.7.2 and is available here: http://www.milesburton.com/?title=Dalla ... ary#Github
- GratefulDread
If I use the most recent version of the library (3.7.2), I get even more errors when I try to compile the code. I am using the most recent version of the OneWire library (version 2.2) but is this possibly the incorrect version?adafruit_support_bill wrote:The code for the tutorial was compiled with the latest version which is 3.7.2 and is available here: http://www.milesburton.com/?title=Dalla ... ary#Github
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:85:24: error: WConstants.h: No such file or directory
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp: In constructor 'OneWire::OneWire(uint8_t)':
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:93: error: 'digitalPinToBitMask' was not declared in this scope
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:94: error: 'digitalPinToPort' was not declared in this scope
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:94: error: 'portInputRegister' was not declared in this scope
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::reset()':
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:127: error: 'delayMicroseconds' was not declared in this scope
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:134: error: 'delayMicroseconds' was not declared in this scope
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'void OneWire::write_bit(uint8_t)':
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:157: error: 'delayMicroseconds' was not declared in this scope
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:165: error: 'delayMicroseconds' was not declared in this scope
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp: In member function 'uint8_t OneWire::read_bit()':
C:\Users\Barry\Documents\Arduino\libraries\OneWire\OneWire.cpp:185: error: 'delayMicroseconds' was not declared in this scope
- adafruit_support_mike
That's an IDE version issue.
The Arduino IDE is built on top of the Wiring project, which is a more general system for making computers talk to programmable hardware. When the Arduino team decided to build their own version just for Arduino hardware, they moved some of the information around.
What you need to do is replace this line:
With this:
#include "WConstants.h"
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
- GratefulDread
Cool, thanks! Unfortunately, the line:adafruit_support_mike wrote:That's an IDE version issue.
With this:Code: Select all
#if ARDUINO >= 100 #include "Arduino.h" #else #include "WProgram.h" #endif
You need to modify the OneWire library reported in the error messages:
- Franklin97355
Make sure this code is in the DallasTemperature.cpp file and tell us which version of the IDE you are using.
You must be using a pretty old version of the OneWire library.
Try this one: http://www.pjrc.com/teensy/td_libs_OneWire.html
Well the newest OneWire library had something similar if you use it on an attiny platform... depending on what core you use.
I remedied that by adding code to the newest OneWire.h, kind of akin to what is described above
