I got some Problems with the LSM9DS0 Breakout and (maybe) with the Library. I rewrote the Library to use it in Atmel Studio with C but it looks
like it doesnt calcuclate the gyro correctly.
After initialising and configuring it for 245DPS the Registers for the Gyro are: CTRL_REG1_G: 0x0F, CTRL_REG4_G: 0x00
To calculate the data, i read the 6 Registers (Xl,Xh,Yl,Yh,Zl,Zh) and multiply it with 0.08F but it always says that the device is moving.
Is the Calibration wrong or could be the calculation wrong?
~gfc
Gyro Calibration of the LSM9DS0 with the ATMEGA1284P in C
- gfcwfzkm
Re: Gyro Calibration of the LSM9DS0 with the ATMEGA1284P in
How did you calibrate it? Calibrating a gyro requires subjecting it to known rotation rates are reading the output. The differences between the output values and the known rate are you calibration correction factors.Is the Calibration wrong
The two primary types of error in MEMS devices like the gyro are zero offset (which looks like what you are seeing) and scale. .
- gfcwfzkm
I didnt calibrated it by myself yet but it was an idea that this could be wrong (and the reason for the results).
You said that the error could be a zero-offset. But how can i fix it?
In the Library you use Float-Numbers for the different ranges to calculate the degrees per second. Could these numbers be wrong?
Like in your Library i use 0.061 for 2G (for high precision) and with that number it calculates the degrees per second.
Zero offset errors are typical for MEMS sensors like your Gyro. You fix it in software by subtracting the zero offset error from the reading.
http://www.digikey.com/en/articles/tech ... ms-sensors
Zero-rate level (some vendors call this the offset calibration error) is the output generated even if there is no rotation. The previously-mentioned LY3100ALH is specified at 1.5 volts, far in excess of the device’s 1.1 mV/dps sensitivity. Clearly this must be nullified by the designer. VTI Technologies’ CMR3000 has a ±2000 dps range, but the zero-rate error, at ±200 dps, is fully ten percent of the unit’s range. As mentioned, for absolute measurements one must calibrate the sensor.
- gfcwfzkm
Thank you, that solved my Gyro-Problem.
I came to one of your tutorials to get AHRS-Data (For Pitch and Roll). I tried to use it but sadly i get very strange values back. I rewrote it to use it in AtmelStudio-C. Im giving it the calculated Accleration-Values (That you see in the screenshot, the 'Accel'-Line(s))
Could i have a Library problem or am i giving it the wrong values? Thats what im using.
I didnt changed much. Just renamed the variables (accel_event, mag_event and replaced orientation->roll to float roll...)
// Compute orientation based on accelerometer and magnetometer data.
void getOrientation(lsm9ds0_sensor* accel_event, lsm9ds0_sensor* mag_event)
float const PI_F = 3.14159265F;
float pitch;
// roll: Rotation around the X-axis. -180 <= roll <= 180
// a positive roll angle is defined to be a clockwise rotation about the positive X-axis
// y
// roll = atan2(---)
// z
// where: y, z are returned value from accelerometer sensor
float roll = (float)atan2(accel_event->y, accel_event->z);
// pitch: Rotation around the Y-axis. -180 <= roll <= 180
// a positive pitch angle is defined to be a clockwise rotation about the positive Y-axis
// -x
// pitch = atan(-------------------------------)
// y * sin(roll) + z * cos(roll)
// where: x, y, z are returned value from accelerometer sensor
if (accel_event->y * sin(roll) + accel_event->z * cos(roll) == 0)
pitch = accel_event->x > 0 ? (PI_F / 2) : (-PI_F / 2);
else
pitch = (float)atan(-accel_event->x / (accel_event->y * sin(roll) + accel_event->z * cos(roll)));
// heading: Rotation around the Z-axis. -180 <= roll <= 180
// a positive heading angle is defined to be a clockwise rotation about the positive Z-axis
// z * sin(roll) - y * cos(roll)
// heading = atan2(--------------------------------------------------------------------------)
// x * cos(pitch) + y * sin(pitch) * sin(roll) + z * sin(pitch) * cos(roll))
// where: x, y, z are returned value from magnetometer sensor
float heading = (float)atan2(mag_event->z * sin(roll) - mag_event->y * cos(roll), \
mag_event->x * cos(pitch) + \
mag_event->y * sin(pitch) * sin(roll) + \
mag_event->z * sin(pitch) * cos(roll));
// Convert angular data to degree
roll = roll * 180 / PI_F;
pitch = pitch * 180 / PI_F;
heading = heading * 180 / PI_F;
sprintf(buffer, "\n\rRoll: %d Pitch: %d Heading: %d", roll, pitch, heading);
uart_puts_all(buffer);
In your sprintf format string you are using %d. It is trying to interpret your floating point values as integers.
- gfcwfzkm
^^ fail, now i see it.
Thanks, that solved my last problem.
~gfc
~gfc
- kcparker
Could you elaborate on which number is the zero offset? My tilt sensor is also off and I'd like to fix this.
Thank you
Thank you
- Franklin97355
@kcparker. If you are having a problem start a thread, explain your problem, tell us what you have tried to resolve it and perhaps we can help.
