Hi - I'm a total noob, and trying to research as much as poss, but come to a standstill!
Is it possible to connect a L3GD20H gyro to a Flora? The only info I can find is about connecting to an Arduino...
Ultimately I want to use motion info to trigger playback from my Audio FX soundboard - i.e. if degrees per second crosses a threshold then trigger a sound - possibly a sound each for x, y and z.
Some help getting started would be great.
L3GD20H Gyro and Flora
- adafruit_support_bill
Re: L3GD20H Gyro and Flora
It should work with a Flora also. Just connect:
GND->GND
SDA->SDA
SCL->SCL
3.3v->3Vo
You can use the same library also.
GND->GND
SDA->SDA
SCL->SCL
3.3v->3Vo
