Sir,
I received my replaced sensors but i regret to inform you that even the new ones are behaving the same way as the older sensors. It can search only the last enrolled finger and that too returns an id 0 irrespective of id assigned to it.
I tried with a different arduino and also a fresh copy of software and library but it fails to work.
Kindly give an appropriate solution.
PROBLEM WITH FINGER PRINT SENSOR
Re: PROBLEM WITH FINGER PRINT SENSOR
We have tested some of these in-house and have reproduced the problem. It appears that there has been a design change that affects our most recent shipment. We are checking with the manufacturer to find a solution.
- niks912
Sir,
My whole project is getting delayed because of the product and i am really running short of time. Can you please update me on a solution as soon as possible.
This customer has reported a solution. We have not verified it yet:
http://forums.adafruit.com/viewtopic.ph ... 36#p365470
- niks912
Yes, it works now. Thanks A lot.
Can you please suggest how can i interface two fingerprint sensors in the same arduino board.
Thnaks
Thnaks
You can set up a second SoftwareSerial port for the other one. Just be aware that you can only listen on one port at a time. You have to call the "Listen()" command to switch between them. http://arduino.cc/en/Reference/SoftwareSerialListen
The other option is to use a Mega which has multiple hardware serial ports.
- niks912
Sir,
The sensor still doesn't work with SFG demo software. Have you found any solution for it.
- adafruit_support_rick
The SFG Demo software is buggy. I can't get my own copy to work. It works on some machines and not on others. I've tried a lot of things, but I never found a way to make it work
- niks912
So what is the solution now.
I bought this product paying a lot more than local available product and now it doesn't serve the purpose.
We sell these for use with Arduino. Does it work with the Arduino example code?
- niks912
Depends on machine. It works on some machine and doesn't on others.
And in your product description page you have clearly mentioned the windows software where it works.
Expecting a better solution from you.
Well, I just tried something I never tried before, and it actually works with SFGDemo. I tried connecting the fingerprint sensor through one of these:
https://www.adafruit.com/product/954
- niks912
So, do i need to buy these cables now or can i avail them as a part of sensor
You can buy one of those cables.
Or, if you're not satisfied with this solution, please email [email protected] for a refund.
- vincenzinodp
HI!
I have also received a re-104 with a usb cable pourchased from amazon and connecting with windows software there are problem the system know a usb to ttl and set a com1 but the software is unable to contact the device that flash when usb is inserted but after remain off and theare are the open device error
please can you help me ?
best regards
vincenzino
best regards
vincenzino
