Need Help With Project, LDR, PIR, LED (Arduino)
For Adafruit customers who seek help with microcontrollers
Kenny407
Post by Kenny407 »
Hey guys, I'm new to micro controllers and need some help with my final project for school. I'm doing a smart street lighting system, the major components are:
LDR Sensor
PIR Sensor( Parallax)
LED
220 ohm resistor
10k ohm resistor
Arduino UNO R3 SMD
Transistor 2N3904
Basically how it works
1, Once the LDR sensor detects its dark out the motion sensor will become active
2. If nothing is in the range of the motion sensor the led will be dimmed down
3. If something triggers the motion sensor the LED will go to full brightness for 5 seconds and then dim down again
Thats the basic operation of the system it will be powered by a 12v 8ah battery that is hooked up to a 10w Solar panel. I had it working with just the photocell, once i added the code for the pir motion sensor the led just stays on continuously and doesn't turn off. I haven't yet added the dimming/ brightening part yet and don't really know how to, I was going to use the 2n3904 transistor to regulate the voltage to the led but if you guys have a better idea let me know.
Anyways heres my circuit diagram and code that im using
if you want to try the code heres a link
http://www.tinkerhobby.com/motion-and-l ... ent-139574
Any help would be greatly appreciated guys, Im so lost when it comes to this stuff ( Im a hydro stream guy, never touched a micro controller )
Re: Need Help With Project, LDR, PIR, LED (Arduino)
That doesn't make sense with the code you posted. Even if the PIR sensor were stuck on, the LED should turn off for 1 second after being on for 5 seconds.
It is actually quite simple to do with PWM. You don't even need the transistor.
https://learn.adafruit.com/adafruit-ard ... ss-control
Kenny407
Post by Kenny407 »
Thanks for the code for uthe dimming, and yeah im just trying to get the photocell and motion sensor part to work right now but its not going to well lol
The_Electro_Junkie
Post by The_Electro_Junkie »
Your PIR Sensor does not have a trigger selector. Maybe you need a different PIR. The trigger selector allows it to remain on until reset after detection of motion or to stay on for only 5 seconds. May be possible with code but I am not famillar with that sensor.
Kenny407
Post by Kenny407 »
Well thats no good which sensor do I need?
Kenny407
Post by Kenny407 »
Got it working, now i just have to disable the circuit from working when its light out and add the dimming
Return to “Microcontrollers”
