Help with bootloader on Gemma v2
For Adafruit customers who seek help with microcontrollers
tylercoy51
Post by tylercoy51 »
I try loading an example bootloader but it says no such file. I know its installed I'm using the adafruit Gemma v2 and arduino with all required drivers installed.
adafruit_support_rick
Re: Help with bootloader on Gemma v2
Post by adafruit_support_rick »
You're trying to repair the bootloader on a Gemma? You need to connect an Arduino Uno and upload the bootloader repair sketch:
https://learn.adafruit.com/introducing- ... bootloader
tylercoy51
I'm not trying to repair it but load the example file. It comes up with an error saying the boot-loader file doesn't exist and i used the easy instillation on your webpage. thanks for the help.
Loading the example file is not the same as loading a bootloader. You do not use the load bootloader menu item.
Load the example in the Arduino IDE and click the upload button.
The only other thing you have is to make sure that the USBtiny programmer is selected
tylercoy51
Okay thanks for all your help.
tylercoy51
that solved my boot-loader issue but its now saying this
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
You have the press reset on the Gemma right before the upload. The red LED should be pulsing when the upload begins. It will pulse for 10 seconds after you press reset.
tylercoy51
Thanks for all your help but one more problem came up and it says fatal error: Adafruit_NeoPixel.h: No such file or directory
compilation terminated.
Error compiling.
tylercoy51
That was fixed i installed the .h file in the libraries and im still getting the usb device not found even while its in boot-loader mode
What kind of operating system are you running on? Windows? Mac?
Return to “Microcontrollers”
