Hi!
I tried many times to upload my FLORA to my Mac Pro but I failed. I have installed the Arduino IDE and have finished programming. I tried to press the RESET button several times but the chip still failed to connect to my computer.
Please help!!!
Thanks a lot!
Can't upload FLORA?!
- adafruit_support_rick
Re: Can't upload FLORA?!
Please try some different USB cables and a different USB port? Also try connecting through a self-powered hub if you have one.
When you press the Reset button, what does the red LED do? Does it pulse for 10 seconds or so?
What error are you getting from Arduino? can you post the output from the IDE?
- PatZ
Thank you very much for your reply!
When I press the RESET button, the red LED will slowly flash for 10 seconds, and then the yellow LED on the left with "RX" on it will flash once before the red LED stops flashing.
When I press VERIFY or UPLOAD on the Arduino IDE, the bar bellow will show: "Error compelling. sketch_jun01a. ino:1:31: fatal error: Adafruit_NeoPixel. h: No such file or directory compilation terminated. Error compelling. "
Thank you!
Thank you!
That error means the compiler can't find the library that makes NeoPixels work.
Have you downloaded that from Github and installed it in the sketchbook/libraries folder?
The NeoPixel library is here:
https://github.com/adafruit/Adafruit_NeoPixel
Here is a tutorial on libraries and how to install them:
https://learn.adafruit.com/adafruit-all ... nstall-use
- PatZ
Thank you very much!
I have already installed the library. However, my FLORA still cannot be uploaded to my Mac, and the IDE shows this:
Arduino: 1.6.4 (Mac OS X), Board: "Arduino Uno"
Sketch uses 2,564 bytes (7%) of program storage space. Maximum is 32,256 bytes.
Global variables use 38 bytes (1%) of dynamic memory, leaving 2,010 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "COM1": No such file or directory
ioctl("TIOCMGET"): Inappropriate ioctl for device
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
Please help. Thanks a lot!
- PatZ
Also, the LEDs on the chip still flash in the same manner.
Thank you!
Thank you!
You have to select 'Adafruit FLORA' as the board type.PatZ wrote:Arduino: 1.6.4 (Mac OS X), Board: "Arduino Uno"
If you haven't done so already, add the FLORA to the IDE list of board types by following this tutorial:
https://learn.adafruit.com/add-boards-arduino-v164
- PatZ
Thank you so much for the suggestion!
However, I can't find the setting page on my Mac to make the changes you have shown me. Is it from the app or the file or something?
Thanks again!
Thanks again!
- PatZ
Ah... Just now some errors occurred, but I have already successfully uploaded. Thank you so much for your help! I have learned a lot from your suggestions!
