I have created an application using the Adafruit 31855 library, which works fine on a pro mini, but fails with tinydebugger errors on the pro micro.
Loading an unmodified sketch with only setup, loop and the library included, the results are the same.
Various other sketches compile, load and run OK on the pro micro if the library is not included. Is the tiny debugger necessary to use the amplifier?
Have I overlooked something?
Roger
31855 Library fails on arduino pro micro, OK on pro mini
- RogerBlair
Re: 31855 Library fails on arduino pro micro, OK on pro mini
The Pro Mini uses the same ATmega328 as the Arduino Uno. The Pro Micro uses the same ATmega32u4 as the Leonardo.
I know the SPI pins are different on the two microcontrollers, and they probably have different pinouts between the two devices.
