so when i Got the 16 x12 servo shield I loaded the library and compiled the sample code and it worked fine. I've been doing 10 of problem solving to try to get the shield to work with my mega 2560 chip and I unfortunately have not been successful. So I just decided start from the beginning and to start working forward again. Went to go upload the sample code and it will compile and upload fine but when you actually run it "servo sample code" in the serial monitor it will display "16 channel servo test!" and thats it. The first time when I uploaded it it would originally give in That prompt and then count from 0 to 15 as it moved from one servo to the next. I didn't change anything at the sample code, tried uninstalling and reinstalling the library, have the 2 power sources as required, and everything is soldered properly to the best
knowledge it seems as if everything is in place correctly it's just not running. Read the support information on the shield numerous times but unfortunately I'm having lots of issues even doing very simple tasks with it. I don't know if the shield is bad? Maybe you can get some insight. Typical below
This is an example for our Adafruit 16-channel PWM & Servo driver
Servo test - this will drive 16 servos, one after the other
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/products/815
These displays use I2C to communicate, 2 pins are required to
interface. For Arduino UNOs, thats SCL -> Analog 5, SDA -> Analog 4
products from Adafruit!
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN 150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 600 // this is the 'maximum' pulse length count (out of 4096)
// our servo # counter
uint8_t servonum = 0;
Serial.begin(9600);
Serial.println("16 channel Servo test!");
pwm.begin();
pwm.setPWMFreq(60); // Analog servos run at ~60 Hz updates
// you can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. its not precise!
void setServoPulse(uint8_t n, double pulse) {
double pulselength;
pulselength = 1000000; // 1,000,000 us per second
pulselength /= 60; // 60 Hz
Serial.print(pulselength); Serial.println(" us per period");
pulselength /= 4096; // 12 bits of resolution
Serial.print(pulselength); Serial.println(" us per bit");
pulse *= 1000;
pulse /= pulselength;
Serial.println(pulse);
pwm.setPWM(n, 0, pulse);
// Drive each servo one at a time
Serial.println(servonum);
for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
pwm.setPWM(servonum, 0, pulselen);
delay(500);
for (uint16_t pulselen = SERVOMAX; pulselen > SERVOMIN; pulselen--) {
delay(500);
servonum ++;
if (servonum > 15) servonum = 0;
[/img]
Again this should be the exact code in the sample from what i understand.
