Adafruit 9-DOF Accel/Mag/Gyro+Temp Breakout Board - LSM9DS0
- sk854016
Hello, I am very new to circuitry and was wondering if the Adafruit 9-DOF Accel/Mag/Gyro+Temp Breakout Board - LSM9DS0 would be suitable to take info from a sensor and relay it to a light to command the light to turn on? The sensor I am using is a Omron D6t Thermal sensor. https://www.components.omron.com/compon ... epaper.pdf
- Franklin97355
Re: Adafruit 9-DOF Accel/Mag/Gyro+Temp Breakout Board - LSM9
Your sensor should communicate directly to your microcontroller (which you will need) Then the rest is software to turn on the light (with relay or MOSFET if needed)
- sk854016
What microcontroller would you recommend? So this product wouldn't work with the sensor?
