GRBL
- adafruit_support_rick
Re: GRBL
Hex files loaded into flash memory on the processor chip are permanent
Re: GRBL
You can overwrite the contents of the chip's program memory with an In-System Programmer several thousand times. The Flash array will hold the most recent program for an estimated 100 years, or until you replace it with something else.
A microcontroller running the GRBL code probably wouldn't be able to run standard Arduino sketches unless you replace the firmware with an Arduino bootloader.
