Hi Adafruit (or anybody else),
I would like to use the controller app together with the bluefruit micro. It works perfect with the sample sketch but I can't get it running without the serial monitor open? Any idea how to fix this?
Regards,
David
Running Bluefruit Micro without Serial Monitor
- DavidTruyens
Re: Running Bluefruit Micro without Serial Monitor
Could you post a link to the code you're using please?
- DavidTruyens
Hi Mike,
it's because of this line (quite obvious):
while (!Serial); // required for Flora & Micro
It runs fine without that line, but apparently it's required? Is there a reason for that?
Regards,
David
Regards,
David
If you don't want to use the Serial interface, just delete that line and any other references to Serial in the code.
