Arduino robot video HOWTOs
Postby thoughtfix » Mon May 23, 2011 2:48 pm
Hey Adafruit community:
One thing I learned while I was a mobile tech blogger: How to take technical operations and explain them in human readable ways. I am now shifting focus to Arduino robotics and have an Arduino Uno, a motor shield, some motors, and more headed to my home. I will document every step of the build and write/record HOWTOs to post online.
Are there any products around here that can be used in a home robot that need more documentation? I'll buy them, of course. I just would love to give back to the community whenever possible and demonstration videos seem to be in demand.
If you google ThoughtFix, you can see a lot of what I have done already. Keep in mind that I sold off TabletBlog.com and the new owner removed all my old content - so any reference to TabletBlog is now stale.
Give me some underdocumented suggestions for parts and I'll figure out the integration and document it!
thoughtfix
Re: Arduino robot video HOWTOs
Postby adafruit » Fri May 27, 2011 4:47 pm
you should use whatever works best, we have a few different motors servos and sensors
Postby oldELECTROguy » Mon May 30, 2011 5:56 pm
sight,sound,motors,sound,talk,grippers,avoid collisons,AI....is that enought
oldELECTROguy
Postby thoughtfix » Wed Jun 08, 2011 11:28 am
So far:
- Got the Motor Shield assembled and working
- Got four sensors (one PING))), two IR (just ordered two more this morning) and a rear bumper working.
- Working hard on the code...there seem to be too many blind spots.
- Set up a wickedly cool power supply.
The rear bumper is an exercise I think others would enjoy. It employs Shape Lock mold-able plastic and works quite well:
http://www.youtube.com/watch?v=qjv27BdzZT8
thoughtfix
Postby thoughtfix » Fri Jun 10, 2011 2:02 am
I love you and all that you do. It works.
http://pastebin.com/LQ1B2m0X
http://www.youtube.com/watch?v=R8vPu7YpqlI
Autonomous roving robot
Parts:
   -Arduino Uno
   -Parallax PING))) ultrasonic sensor
   -Adafruit motor shield http://www.ladyada.net/make/mshield/
   -2WD Mobile Platform http://www.makershed.com/ProductDetails.asp?ProductCode=MKSEEED7
   -Lever switch (for back bumper)
   -Indicator LED
   -Energizer XPAL XP8000 battery (custom cable and self-built regulator for motors)
Original motion functions and design from Robot Living 8/30/2010
Code borrowed from example sketches:
   -Ping
Original code created June 2011
by Daniel Gentleman
thoughtfix@gmail.com
http://thoughtfix.com
Additional credits:
Victor Brilon
Mark Balliet
luckylarry.co.uk for the math on the Sharp sensor
Advice from arduino.cc forum
Advice from from #arduino on irc.freenode.net
Advice from adafruit forums
Further inspiration
      -Adafruit Industries
      -Make Magazine
Adafruit Motor shield library
Wiring (remember, analog 0 is also digital 14)
- Left motor to Motor 1
- Right motor to Motor 2
- LEDs on digital 15 and 16
- PING))) on digital 17
- Sharp IR sensors on digital 18 and 19
- Lever switch (bumper attached) on digital 14
- USB power (from a USB battery) to the Arduino
- Regulated power (I used an Energizer XPAL XP8000 regulated to +5v) for servos
#include <AFMotor.h>
AF_DCMotor motorL(1, MOTOR12_1KHZ);
AF_DCMotor motorR(2, MOTOR12_1KHZ);
int BSensor = 14; //Back sensor
int FLEDPin = 15; //Forward LED
int BLEDPin = 16; //Backup LED
int pingPin = 17; //Front sensor
int FSensorR = 18; //Front right sensor
int FSensorL = 19;  //Front left sensor
int count = 0;
int b=0;
int bs=0;
int sensorValue;
int forwardSensor;
int sensorValueB=1;
int leftSensor=0;
int rightSensor=0;
int obstacle=0;
  randomSeed(analogRead(0));
  pinMode(BLEDPin, OUTPUT);
  pinMode(FLEDPin, OUTPUT);
  pinMode(BSensor, INPUT);
  pinMode(pingPin, INPUT);
  pinMode(FSensorR, INPUT);
  pinMode(FSensorL, INPUT);
  motorL.setSpeed(200);
  motorR.setSpeed(200);
  motorL.run(RELEASE);
  motorR.run(RELEASE);
void loop()
  uint8_t i;
  Forward();
void Forward () // Charge forth!
  digitalWrite(FLEDPin, HIGH);
  digitalWrite(BLEDPin, LOW);
  ForwardSensor ();
  if (obstacle == 0){ //unless something is in the way
  Serial.println("Going forward.");
  motorL.run(FORWARD);
  motorR.run(FORWARD);
void ForwardSensor ()
  leftSensor = (ForwardSensorLeft());
  rightSensor =(ForwardSensorRight());
  forwardSensor = (getDistance());
  delay(30);
  //  Serial.print(leftSensor);
  //  Serial.println(" left");
  //  Serial.print(rightSensor);
  //  Serial.println(" right");
  //  Serial.print(forwardSensor);
  //  Serial.println(" front");
  if (forwardSensor <=30 || leftSensor <= 30 || rightSensor <= 30 )
  { // I gave 10cm of "wiggle room" so it doesn't turn endlessly.
    obstacle=1;
    if (ForwardSensorRight() > (ForwardSensorLeft()-10)){
      RightBackward();
    else if (ForwardSensorRight() < (ForwardSensorLeft()-10)){
      LeftBackward();
    else{
      Backward();
  else {
    obstacle = 0;
  sensorValue=0;
  rightSensor=0;
  leftSensor=0;
int ForwardSensorRight ()
{ // This function is here so you don't have to re-write code
  // if you use a different sensor.
  sensorValue = irDistance(FSensorR);
  return sensorValue;
int ForwardSensorLeft ()
  sensorValue = irDistance(FSensorL);
  return sensorValue;
void BackwardSensor ()
  sensorValueB = digitalRead(BSensor);
  if (sensorValueB == 1)
    Serial.println("Object detected while going backwards.");
    for (bs=0; bs <= 3; bs++) // Add blinky lights for personality on detecting object when backing up.
      digitalWrite(BLEDPin, HIGH);
      delay(5);
      digitalWrite(FLEDPin, LOW);
      delay (5);
    b=31;
    bs=0;
    Forward();
  sensorValueB = 0;
void Backward ()
  Serial.println("Going backwards.");
  do
    b++;
    motorL.run(BACKWARD);
    motorR.run(BACKWARD);
    delay(20);
    BackwardSensor ();
  while (b < 20);
  b=0;
void LeftBackward ()
  Serial.println("Going left backwards.");
  do
    b++;
    //    Serial.print("b = ");
    //    Serial.print(b);
    BackwardSensor ();
    delay (20);
  while (b < 20);
  b=0;
void RightBackward ()
  Serial.println("Going right backwards.");
  do
    b++;
    //    Serial.print(b);
    BackwardSensor ();
    delay (20);
  while (b < 20);
  b=0;
int getDistance()
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
reread:  // takes another reading if cm=0
  long duration, cm;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  cm = microsecondsToCentimeters(duration);
  //  Serial.print(cm);
  //  Serial.print("cm");
  //  Serial.println();
  delay(100);
  //  if (cm == 0) {
  //    goto reread;
  return cm;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return (microseconds/58);
int irDistance(int irPin) {
  float volts = analogRead(irPin)*0.0048828125;   // value from sensor * (5/1024) - if running 3.3.volts then change 5 to 3.3
  int distance = 32.5*pow(volts, -1.10);          // theretical distance 32.5/ (1/Volts)S
  //  Serial.print(distance);
  //  Serial.print(" from ");
  //  Serial.println(irPin);
  delay (10);
  return distance;        // print the raw analog value to serial port
---Daniel Gentleman
Open source projects: http://thoughtfix.com
thoughtfix
Postby paulolondres » Thu Aug 23, 2012 8:30 pm
Hi sir, Thanks for posting this code for make a robot.
I have the HC-SR04 instead of ping , how i have to change the code for make my robot?
I want to make a vaccum robot using your example.
paulolondres
Return to Arduino
Users browsing this forum: No registered users and 8 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
