Using Arduino Due with MAX31855 thermocouple amplifier
by sungsuk on Thu Oct 31, 2013 8:24 am
Hi, I am having a hard time using MAX31855 thermocouple amplifier with Arduino Due for school project. I just need serial data outputs(temperatures) and it doesn't matter if I uses normal digital pins or SPI pins. Since I am an mechanical engineering student, I have limited experience with programming.
I know libraries of MAX31855 (https://github.com/adafruit/Adafruit-MAX31855-library) are based on AVR like for Mega and Uno so they are not working with Due which uses ARM.
I have been trying to modify the following codes but all of them didn't work.
1. http://forum.arduino.cc//index.php?PHPS ... c=150629.0
This guy uses SD card and it doesn't shoots outputs.
2. http://forum.arduino.cc//index.php?PHPS ... c=150351.0
The first two codes look OK for me but it just shoots 0 after three loops. Also, the first output that he got (1000000010000000100000001) looks like digital output data which are not converted to decimal numbers.
The last code didn't work at all.
I know converting AVR based libraries to ARM based libraries is very challenging. Is there any way that I can run MAX31855 with Due?
Thank you.
sungsuk
Re: Using Arduino Due with MAX31855 thermocouple amplifier
by adafruit_support_rick on Thu Oct 31, 2013 11:08 am
We are working on porting our libraries to the Due, but we haven't done the MAX31855 yet. We have no ETA. Sorry.
by franklin97355 on Thu Oct 31, 2013 1:44 pm
Page 8 through 10 of this document http://www.adafruit.com/datasheets/MAX31855.pdf should give you the information to get the raw data from the MAX31855 and then you can manipulate it as necessary for your project.
franklin97355
by sungsuk on Fri Nov 01, 2013 3:38 am
Thank you for fast reply. I inseted "Serial.println(data.bit8[i]);" in the setup and got outputs as following.
1
1
1
1
1
1
1
1
and when I changed the temperature(touching thermocouple), I got like this
Since the binary numbers stay same, I guess the raw data does not represent the temperature. How do you think?
#include <SPI.h>
union FourByte{
    unsigned long bit32;
    unsigned int bit16[2];
    unsigned char bit8[4];
int SlavePin1 = 10; //Thermocouple #1
long unsigned data;
  Serial.begin(9600);
  pinMode(SlavePin1, OUTPUT);
  digitalWrite(SlavePin1, HIGH); //Disable SS
  SPI.begin(SlavePin1);                // Setup SPI to use pin 4 as CS.
  SPI.setBitOrder(MSBFIRST);
  SPI.setDataMode(SlavePin1,1);        // Use SPI Mode 1 (CPOL = 0, CPHA = 1)
  SPI.setClockDivider(SlavePin1, 21);  // Set SPI Clock divider to 21.(4MHz)
unsigned long transfer(unsigned long value){
  FourByte data = {value};
  for(byte i = 0; i < 4; i++){
    data.bit8[i] = SPI.transfer(SlavePin1, data.bit8[i]);
    delay(1);
  return data.bit32;
  digitalWrite(SlavePin1, LOW);
  unsigned long someValue = 0xFFFFFFFEUL; //No MOSI on MAX31855, dosent matter what is sent.
  data = transfer(someValue);
  Serial.println(data, BIN);
  delay(1000);
sungsuk
by federico.belfi on Tue Dec 10, 2013 4:51 pm
still no news about? I have two thermocouple and i must read to do a PID controller. Using an Arduino DUE :D
Thank you for the help.
Bye
federico.belfi
by adafruit_support_rick on Fri Dec 13, 2013 12:14 pm
Try the attached version of the library and see if it works for you:
Adafruit_MAX31855_Due.zip
(8.8 KiB) Downloaded 42 times
