Hello.
What part(s) would I need to convert this product
Adafruit "Music Maker" MP3 Shield for Arduino
http://www.adafruit.com/products/1790
into this product:
Adafruit "Music Maker" MP3 Shield for Arduino w/3W Stereo Amp
http://www.adafruit.com/product/1788
Thank you in advance.
Adding amp to non-amped "Music Maker" MP3 Shield
- embedgeek
- Franklin97355
Re: Adding amp to non-amped "Music Maker" MP3 Shield
The amplifier and some wire.
- embedgeek
Thank you. I ordered the necessary parts you suggested. What connections do I need to make from https://www.adafruit.com/products/1790 to the ST2012 ?
- Franklin97355
You need to connect the right and left outputs of the music maker to the right and left inputs of the amplifier.
- embedgeek
I did make the proper R/L +/- connections from the shield to the ST2012. I also connected GND and VDD on the ST2012 to the GND and 5V on the shield, respectively. Still a no go. I must be missing something
- Franklin97355
Could you post clear pictures of your board and the connections to it?
- embedgeek
I figured this alone would suffice. Do I need to adjust my code if I add the ST2012?
- Attachments
- shield_to_st2012_connections.jpg (612.86 KiB) Viewed 361 times
- Franklin97355
To be safe run VDD on the amp to 5V on the shield. The amp can't take more than 5.5V. Also how are you powering the shield?
- embedgeek
Ok, I updated my wiring and still nothing. I can, however, still hear the sounds via the headphone jack on the shield. I am powering the shield via USB on the arduino uno that it is connected to.
- Attachments
- shield_to_st2012_connections_updated.png (843.3 KiB) Viewed 351 times
- Franklin97355
Could you post clear pictures of both sides of your board showing any soldering you have done and the connections to it?
