Hi there
I've got my Metro 328 hooked up and am running 1.0.5. I downloaded and copied the "optiboot" folder to my hardware dir.
FYI: I tried this in 1.6.1 and 1.6.5 but the optiboot contents didn't show up there at all.
I see several board prefixed with "optiboot" under the tools menu, but none are the Metro. Is there another hardware/boards definition that I need to install, the instructions on the product page are pretty inadequate with regards to this.
---Raymond
Metro 328 in Arduino 1.0.5
- raygeeknyc
- Franklin97355
Re: Metro 328 in Arduino 1.0.5
What is it you are trying to do? The Metro should program using the Arduino Uno board setting.
- raygeeknyc
Thanks, that's a working answer then. I did get a sketch running on it as an Uno but there was mention in other threads here about a specific board entry for the Metro, and additionally it looks like the PB5 designation for the red LED isn't set correctly in the Uno board description as my LED works (I see it blinking while uploading a sketch) but it's not blinking when I write to PB5.
