Arduino inside a Mario Costume
Post here about your arduino projects, get help & ideas, etc!
Moderators: magician13134, adafruit
Postby djmacatack » Mon Oct 05, 2009 12:36 am
Hey guys,
I just put together a costume project using a Wave shield. I don't need help with anything but since I bought everything from Adafruit I thought I'd share. Note that I'm new here so I don't know the forum etiquette.
http://www.youtube.com/watch?v=zj-I0zMkIQk
The code is not very clean because it was recycled from a previous failed project that used more LED's. I used some creative looping to save text space.
#include <AF_Wave.h>
#include <avr/pgmspace.h>
#include "util.h"
#include "wave.h"
#define DEBOUNCE 20
#define swPin 14
int value = 255;
int ledpin[] = {18,19,6,7,8}; //5 output pins declared 1 used
AF_Wave card;
File f;
Wavefile wave;
  byte i;
  digitalWrite(ledpin[1], LOW);//Default off
  Serial.begin(9600);
  for (byte i = 2; i <= 5; ++i) {
    pinMode(i, OUTPUT);
  for (byte i = 1; i <= 5; ++i) {
    pinMode(ledpin[i], OUTPUT);
  for (byte i = swPin + 1; i <= swPin + 3; ++i) {
    digitalWrite(i, HIGH);
  if (!card.init_card()) {
    putstring_nl("Card init failed!"); return;
  if (!card.open_partition()) {
    putstring_nl("No partition!"); return;
  if (!card.open_filesys()) {
    putstring_nl("Couldn't open filesys"); return;
  if (!card.open_rootdir()) {
    putstring_nl("Couldn't open dir"); return;
  switch (check_switches()) {
    case 2:
      playfile(picker(0,1));
      while (wave.isplaying)
        shot();
      break;
    case 3:
      playfile(picker(1,8));
      break;
    case 4:
      playfile(picker(8,11));
void shot()
      digitalWrite(ledpin[1], HIGH);
      delay(200);
      delay(100);
byte check_switches()
  static byte previous[6];
  static long time[6];
  byte reading;
  byte pressed;
  byte index;
  for (index = 0; index < 6; ++index) {
    reading = digitalRead(swPin + index);
    if (reading == LOW && previous[index] == HIGH && millis() - time[index] > DEBOUNCE)
      time[index] = millis();
      pressed = index + 1;
      break;
    previous[index] = reading;
  return (pressed);
char* picker(int low, int high)
  char* str[]={"FIREBALL.WAV", "JUMP1.WAV", "JUMP2.WAV", "JUMP3.WAV", "JUMP4.WAV", "JUMP5.WAV", "JUMP6.WAV", "JUMP6.WAV", "SONG1.WAV", "SONG2.WAV", "SONG3.WAV"};
  int i = random(low, high);
  return str[i];
void playfile(char *name) {
  if (wave.isplaying) {
    wave.stop();
  if (f) {
    card.close_file(f);
  f = card.open_file(name);
  if (f && wave.create(f)) {
    wave.play();
djmacatack
Re: Arduino inside a Mario Costume
Postby adafruit » Mon Oct 05, 2009 11:59 am
damn that is WAY COOL!!!
Postby djmacatack » Fri Oct 30, 2009 5:40 pm
Hey and thanks for the blog mention awhile back. I wanted to post a vid of the finished product. Enjoy.
http://www.youtube.com/watch?v=oiWxle-KvHg
djmacatack
Return to Arduino
Users browsing this forum: Google [Bot] and 2 guests
x
