Tiebreaker - Jeopardy game
Postby isonno » Wed Apr 13, 2011 10:33 pm
My son has recently become obsessed with "Jeopardy", and as part of his set-up, wanted a set of switches to determine who has the answer first.
So, we broke out his ARDX kit (we'd had it since Christmas, but just got around to opening it now) and got to work. We had it up and running in half an hour - pretty neat. It's my first time using the Arduino, though I've been programming MCUs for years.
Here's the sketch:
// This sketch implements a "Jeopardy" style contestant response tiebreaker.
// Each contestant has a toggle switch. When they know the answer,
// they flip it on.  This turns on the corresponding light.
// The light for the first person to flip their switch on blinks.
// Turning all of the switches off resets it.
// J. Peterson, Apr '11
// The LEDs, cathodes connected to ground
int Lights[3] = {13, 12, 11};
// The toggle switches connect the input to ground when closed.
int Switches[3] = { 10, 9, 8 };
// Set to -1 when no winner set.
int winner;
void setup()
  int i;
  for (i = 0; i < 3; i++)
    pinMode(Lights[i], OUTPUT);
    pinMode(Switches[i], INPUT);
    digitalWrite(Switches[i], HIGH);  // Enable pullup
  winner = -1;
  LightsOff();
void LightsOff()
  int i;
    digitalWrite( Lights[i], LOW);
int invert( int value )
  return value == HIGH ? LOW : HIGH;
void loop()
  int i;
  if (winner == -1)
    // Scan the switches looking for a winner
    for (i = 0; (i < 3) && (winner == -1); i++)
      if (digitalRead( Switches[i] ) == LOW)
        winner = i;
  else
       if (i == winner)
         // Blink the winner's light every 100ms
         if (((millis() /100) % 10) & 1)
           digitalWrite( Lights[winner], HIGH );
         else
           digitalWrite( Lights[winner], LOW );
       else   // Turn loser's lights on if switches are on
         digitalWrite( Lights[i], invert( digitalRead( Switches[i] )));
  // Check to see if all the switches are off,
  // and reset the winner & lights if so.
  if ((digitalRead( Switches[0] ) == HIGH)
     && (digitalRead( Switches[1] ) == HIGH)
     && (digitalRead( Switches[2] ) == HIGH))
     winner = -1;
     LightsOff();
isonno
Re: Tiebreaker - Jeopardy game
Postby adafruit_support_bill » Thu Apr 14, 2011 5:33 am
Nice project! A good way to get your son started programming micros. :D
Re: Tiebreaker - Jeopardy game - Pushbutton version
Postby isonno » Mon Apr 02, 2012 3:55 am
We revisited the sketch again this year, modifying it to use pushbuttons instead of toggle switches. This requires adding a "reset" switch for the host to restart the game.
Here's the updated sketch:
// Each contestant has a pushbutton switch. When they know the answer,
// they push it.  This turns on the corresponding light.
// The light for the first person to push their button blinks.
// Pressing the reset switch restarts the game.
// J. Peterson, Apr '12
// The pushbutton switches connect the input to ground when closed.
// Connect to ground to reset the game
int Reset = 7;
int winner;
boolean SwitchPushed[3] = { false, false, false };
void setup()
  int i;
    pinMode( Reset, INPUT );
    digitalWrite( Reset, HIGH );    // Enable pullup
  LightsOff();
// Reset to the initial state.
void LightsOff()
  int i;
  winner = -1;
    SwitchPushed[i] = false;
void loop()
  int i;
  // If no winner selected, first button selects the winner.
  if (winner == -1)
        winner = i;
  else
       if (i == winner)  // Blink winner's light
          else
       else
         // When switch is pushed, record it.
           SwitchPushed[i] = true;
         // Display non-winner lights
         digitalWrite( Lights[i], SwitchPushed[i] ? HIGH : LOW );
  // Reset button
  if (digitalRead( Reset ) == LOW)
    LightsOff();
isonno
Return to Arduino
Users browsing this forum: brownmeister and 10 guests
New Products [103]
LEDs[109]
Cables[61]
