I have an Uno using MySoftSerial to receive a string of numbers on one of the Uno's digital input pins. The serial data is coming from a sensor connected to the Uno, and the sensor outputs a string once a minute in the following format: "234 93 242x" and is followed by a carriage return. I want to separate the string into the 3 integers that are space delimited, throwing away anything that is not an integer(the last character or two), then I want to store the ints so I can do some math and then write them to external memory.
I'm having trouble figuring out how to parse out the individual numbers from serial string. Can someone point me in the right direction? Thanks.
parsing s serial string
- tastewar
Re: parsing s serial string
this should do:
#include <stdio.h>
#include <errno.h>
char *input = "234 93 242x\r"; // just an example, fill this from the serial input
char *nptr, *endptr = input;
long int values[3];
int i;
for (i = 0; i < 3; i++) {
values[i] = strtol(nptr, &endptr, 10);
if (!endptr || endptr == nptr || errno == ERANGE)
return -1; // error
- fat16lib
Here is a C++ extractor that can parse this string.
This sample sketch parses the string and prints the result:
The new version of SdFat has C++ extraction operators, >>, and insertion operators, <<, for parsing and formatting strings in memory and files.
The beta is here http://code.google.com/p/beta-lib/downloads/list
#include <SdFat.h>
// test string
char buf[] = "234 93 242x\r";
int i, j, k;
Serial.begin(9600);
// create an input buffer stream
ibufstream ib(buf);
// parse line with three ints and test for errors
if (ib >> i >> j >> k) {
// print result for success
Serial.println(i);
Serial.println(j);
Serial.println(k);
} else {
// process error
Serial.println("error");
void loop() {}
