TTL Serial Camera - Nothing seems to work
by suranga on Tue Oct 25, 2011 12:34 am
Hi
I have been trying all possible things with my TTL JPEG camera (viewtopic.php?f=25&t=22562); but nothing seems to be working (read almost all the forum postings)...
1. I tried with the example code provided with a UNO board - I always get the version number, resolution etc...but images are corrupted (I can't open them with any image editing tool) . I change buffer length to 32, 16, 64; delay in the .h file to 20, 5 - still no luck!
2. I am using a mac (with os X) so I can't try the CommTool but I was trying to use the Python code (on Python 2.6.6) given in the examples - doesn't work..I receive some bytes and then gets "ERROR READING PHOTO" At the end of this post I have included the complete output (with bytes received printed).
I am not sure if I should power the UNO board separately. At the moment, the UNO board is connected to mac via USB and I use UNO board 5V and GND to power the TTL camera.
I am not sure if the camera is faulty...
Any advice on this matter is greatly appriciated.
Snap!
3516 bytes to read
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\xff', '\xd8', '\xff', '\xfe', '\x00', '$', '\x05', '\x00', '\x0e', '\x01', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', 'x', '\x00', '\xa0', '\x00', '\x08', '\x00', '2']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x0', '0x20', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\x12', '\x0b', 'Q', '\x04', 'Q', '\x04', '\x00', '\x00', '\xff', '\xdb', '\x00', '\x84', '\x00', '\x02', '\x01', '\x02', '\x02', '\x02', '\x01', '\x02', '\x02', '\x02', '\x02', '\x02', '\x02', '\x02', '\x02', '\x03', '\x05', '\x03', '\x03', '\x03']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x0', '0x40', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\x03', '\x03', '\x06', '\x04', '\x05', '\x04', '\x05', '\x07', '\x06', '\x08', '\x08', '\x07', '\x06', '\x07', '\x07', '\x08', '\t', '\x0c', '\n', '\x08', '\t', '\x0b', '\t', '\x07', '\x07', '\n', '\x0e', '\n', '\x0b', '\x0c', '\x0c', '\r']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x0', '0x60', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\r', '\r', '\x08', '\n', '\x0e', '\x0f', '\x0e', '\r', '\x0f', '\x0c', '\r', '\r', '\x0c', '\x01', '\x02', '\x02', '\x02', '\x03', '\x03', '\x03', '\x06', '\x03', '\x03', '\x06', '\x0c', '\x08', '\x07', '\x08', '\x0c', '\x0c', '\x0c', '\x0c']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x0', '0x80', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x0', '0xa0', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\x0c', '\xff', '\xfe', '\x00', '\x05', '\x00', '\x00', '\x00', '\xff', '\xc0', '\x00', '\x11', '\x08', '\x00', 'x', '\x00', '\xa0', '\x03', '\x01', 'v', '\x00', '2', '\x00']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x0', '0xc0', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '!', '\x00', '\x02', '\x11', '\x01', '\x03', '\x11', '\x01', '\xff', '\xc4', '\x01', '\xa2', '\x00', '\x00', '\x01', '\x05', '\x01', '\x01', '\x01', '\x01', '\x01', '\x01', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x01', '\x02']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x0', '0xe0', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\x03', '\x04', '\x05', '\x06', '\x07', '\x08', '\t', '\n', '\x0b', '\x01', '\x00', '\x03', '\x01', '\x01', '\x01', '\x01', '\x01', '\x01', '\x01', '\x01', '\x01', '\x00', '\x00', '\x00', '\x00', '\x00', '\x00', '\x01', '\x02', '\x03', '\x04', '\x05']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x1', '0x0', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\x06', '\x07', '\x08', '\t', '\n', '\x0b', '\x10', '\x00', '\x02', '\x01', '\x03', '\x03', '\x02', '\x04', '\x03', '\x05', '\x05', '\x04', '\x04', '\x00', '\x00', '\x01', '}', '\x01', '\x02', '\x03', '\x00', '\x04', '\x11', '\x05', '\x12', '!']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x1', '0x20', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '1', 'A', '\x06', '\x13', 'Q', 'a', '\x07', '"', 'q', '\x14', '2', '\x81', '\x91', '\xa1', '\x08', '#', 'B', '\xb1', '\xc1', '\x15', 'R', '\xd1', '\xf0', '$', '3', 'b', 'r', '\x82', '\t', '\n', '\x16', '\x17']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x1', '0x40', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', 'v', '\x00', '2', '\x00', '\x00', '\x18', '\x19', '\x1a', '%', '&', "'", '(', ')', '*', '4', '5', '6', '7', '8', '9', ':', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'S', 'T', 'U']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x1', '0x60', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', 'c', 'd', 'e', 'f', 'g', 'h', 'i', 'j', 's', 't', 'u', 'v', 'w', 'x', 'y', 'z', '\x83', '\x84', '\x85', '\x86', '\x87', '\x88', '\x89', '\x8a', '\x92', '\x93', '\x94', '\x95', '\x96', '\x97', '\x98', '\x99']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x1', '0x80', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', '\x9a', '\xa2', '\xa3', '\xa4', '\xa5', '\xa6', '\xa7', '\xa8', '\xa9', '\xaa', '\xb2', '\xb3', '\xb4', '\xb5', '\xb6', '\xb7', '\xb8', '\xb9', '\xba', '\xc2', '\xc3', '\xc4', '\xc5', '\xc6', '\xc7', '\xc8', '\xc9', '\xca', '\xd2', '\xd3', '\xd4', '\xd5']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x1', '0xa0', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['v', '\x00', '2', '\x00', '\x00', 'v', '\x00', '2', '\x00', '\x00', '\xd7', '\xd8', '\xd9', '\xda', '\xe1', '\xe2', '\xe3', '\xe4', '\xe5', '\xe6', '\xe7', '\xe8', '\xe9', '\xea', '\xf1', '\xf2', '\xf3', '\xf4', '\xf5', '\xf6', '\xf7', '\xf8', '\xf9', '\xfa', '\x11', '\x00', '\x02']
['0x56', '0x0', '0x32', '0xc', '0x0', '0xa', '0x0', '0x0', '0x1', '0xc0', '0x0', '0x0', '0x0', '0x20', '0x1', '0x0']
['\x01', '\x02', '\x04', '\x04', 'v', '\x00', '2', '\x00', '\x00', 'v', '\x00', '2', '\x00', '\x00', '\x03', '\x04', '\x07', '\x05', '\x04', '\x04', '\x00', '\x01', '\x02', 'w', '\x00', '\x01', '\x02', '\x03', '\x11', '\x04', '\x05', '!', '1', '\x06', '\x12', 'A', 'Q']
ERROR READING PHOTO
None
File "/Users/suranga/Documents/Arduino/libraries/VC0706/getimage0706.py", line 142, in <module>
photodata = ''.join(photo)
TypeError
suranga
Re: TTL Serial Camera - Nothing seems to work
by adafruit_support_bill on Tue Oct 25, 2011 6:37 am
It looks like you have the right connections since it is communicating to some degree. Do make sure that all your connections are secure, since just one dropped byte would cause an error reading the photo.
The camera only needs 75mA @5v, so you should be fine powering it from the UNO 5v pin.
by suranga on Tue Oct 25, 2011 12:48 pm
Thanks for the comment...
I checked all the connections...In fact, I tried running CommTool on a windows 7 machine (keeping the same connections and same UNO board) and I could get images without any problems! Once this was verified I remove the USB cable from windows machine, connected to max OS X and executed .py code..still gets the same error...Similarly, the Arduino example code too gives me a corrupted image.
Any idea what else should I try?
Suranga
suranga
by adafruit on Tue Oct 25, 2011 2:24 pm
can you try to format your microSD card? or try another card? (worth an attempt!)
by suranga on Tue Oct 25, 2011 2:33 pm
yes I can try...I don't need a SD card to run the .Py code right?
PS: .Py code does not compile on python 3.2; compiles on python 2.6...
suranga
by adafruit_support_bill on Tue Oct 25, 2011 5:46 pm
You need to use the AFMotor library or the AFMotor compatible version of the AccelStepper library. Both are available here: http://www.ladyada.net/make/mshield/download.html
by suranga on Tue Oct 25, 2011 6:45 pm
How does this library relate to TTL Camera Python Example code?...Before I ran the python code, I simply uploaded an empty sketch into UNO...
suranga
by adafruit_support_bill on Tue Oct 25, 2011 7:13 pm
Sorry, right reply to the wrong thread. :oops: I need to pay attention when I multi-task.
Not sure about the python issue. I'm not a python expert, but the error seems to occur after the image read is complete.
by suranga on Tue Oct 25, 2011 7:30 pm
What's the best way to test this camera on Arduino? With the Windows PC I have verified that my connections are okey and camera is working.
But whenever I try with Arduino, (say I read 160*120) there are 3000+ bytes in the camera buffer and I the resulting file is corrupted...
When I tried python code, I realized that there is a function to check every response. Some bytes fails to go though this check and python code exit at that moment.
def checkreply(r, b):
r = map (ord, r)
if (r[0] == 0x76 and r[1] == SERIALNUM and r[2] == b and r[3] == 0x00):
return True
return False
I tried to bypass the response check and I was able to receive almost all the bytes..there were about 4-5 invalid responses, which I think corrupted the image.
I have been trying this over 3 weeks now...could captures a figure with arduino code...
suranga
by adafruit_support_bill on Tue Oct 25, 2011 7:40 pm
Can you post some photos of your connections between the camera and the Arduino?
by suranga on Wed Oct 26, 2011 11:02 am
I have included 3 images: Overall circuit, zoom to Breadboard connections, zoom to Camera connections
This was used with the Python code. When I tried Arduino code, camera's tx and rx was connected to pin 2 and 3 and monitor the output from serial port.
suranga
by adafruit on Wed Oct 26, 2011 11:22 am
where is the microSD card?
by suranga on Wed Oct 26, 2011 11:28 am
This was used with the Python code...For micro SD card example, instead of writing to SD card I wrote the byte into the serial port and tried save data into a JPEG file...
suranga
by adafruit on Wed Oct 26, 2011 12:17 pm
that wont work, it isnt fast enough. follow the tutorial as it is, adding python is just making it more complicated
by suranga on Wed Oct 26, 2011 12:26 pm
Thanks!...I've ordered SD card breakout board from adafruit. I will report how it goes once I re-try the code with SD card
suranga
