Adding in Music to Ada light
by ConUO on Wed Jan 11, 2012 5:14 pm
So I recently finished making the Ada Light:
http://www.ladyada.net/make/adalight/
I remember see a tutorial somewhere where I could re purpose the lights as a music visualizer. Something like
http://www.youtube.com/watch?v=OgiEAk2C66Q
Does anyone have a link or if you could provide me with a quick help guide on how to achieve something like that?
Thank you!
ConUO
Re: Adding in Music to Ada light
by misake on Mon Jun 25, 2012 5:18 pm
I recently looked into doing something similar,
there seems to be a lot of information around regarding music visualisations, particularly look into FFT (fast Fourier transforms).
They are useful for analysing frequencies in audio signals.
A quick search of doing this in processing pointed me to the Minim lib, it contains a lot of audio tools, including FFTs.
I suggest you look at the InputMixer example code, I have attached a version updated to work with Minim 2.0.2 and ControlP5 0.7.5
sketch_audio_test.txt
InputMixer example, rename .pde
(2.34 KiB) Downloaded 81 times
misake
by misake on Mon Jun 25, 2012 6:01 pm
Attached as proof of concept, is the crude mutant child of the Adalight colour swirl script and the inputMixer demo.
Looks kinda cool with some slow dubstep or anything else without too much going on at one time.
My next attempt will make use of FFTs.
audio_adalight.txt
Audio Adalight proof of concept. REname .pde
(4.77 KiB) Downloaded 101 times
misake
by misake on Mon Jun 25, 2012 7:03 pm
FFT example attached, now in stereo.
Next step to do something more appropriate with the colours.
Perhaps change colour rather than brightness based on intensity, green to red?
Also to experiment with other settings available, and conceive some new patterns.
fft_adalight.txt
FFT music vis. rename to .pde
(5.36 KiB) Downloaded 145 times
misake
by adafruit on Wed Jun 27, 2012 1:25 pm
Coool - can you post a video of this when you get it going? its a really smart idea!
by Ronin on Mon Apr 01, 2013 2:59 pm
Can someone help me? I'm getting this error with the files above:
ControlP5 2.0.4 infos, comments, questions at http://www.sojamo.de/libraries/controlP5
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
No glyph found for the Ä (\u00C4) character
Average frames/sec: 0, bytes/sec: 0
User chose Mixers
Using mixer info Primärer Soundtreiber
==== JavaSound Minim Error ====
==== Unable to return a TargetDataLine: unsupported format - PCM_SIGNED 44100.0 Hz, 16 bit, stereo, 4 bytes/frame, little-endian
=== Minim Error ===
=== Minim.getLineIn: attempt failed, could not secure an AudioInput.
01.04.2013 20:58:34 controlP5.ControlBroadcaster printMethodError
SCHWERWIEGEND: An error occured while forwarding a Controller event, please check your code at controlEvent
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at controlP5.ControlBroadcaster.invokeMethod(Unknown Source)
at controlP5.ControlBroadcaster.broadcast(Unknown Source)
at controlP5.ListBox.controlEvent(Unknown Source)
at controlP5.Controller.broadcast(Unknown Source)
at controlP5.Button.setValue(Unknown Source)
at controlP5.Button.activate(Unknown Source)
at controlP5.Button.mouseReleased(Unknown Source)
at controlP5.Controller.setMousePressed(Unknown Source)
at controlP5.ControllerGroup.setMousePressed(Unknown Source)
at controlP5.ControlWindow.mouseReleasedEvent(Unknown Source)
at controlP5.ControlWindow.mouseEvent(Unknown Source)
at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
at processing.core.PApplet$RegisteredMethods.handle(PApplet.java:1123)
at processing.core.PApplet.handleMethods(PApplet.java:1318)
at processing.core.PApplet.handleMouseEvent(PApplet.java:2700)
at processing.core.PApplet.dequeueEvents(PApplet.java:2603)
at processing.core.PApplet.handleDraw(PApplet.java:2277)
at processing.core.PGraphicsJava2D.requestDraw(PGraphicsJava2D.java:243)
at processing.core.PApplet.run(PApplet.java:2140)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.NullPointerException
at music_pde.controlEvent(music_pde.java:202)
... 27 more
Ronin
