How can I make a servo stop when a pin is High?
- zinc55
I have a servo running in a loop, a PIR sensor, and an LED. The LED will go high/low depending on the PIR sensor. Right now, the motor spins at all times. The LED blinks in coordination with the PIR. Is it possible to make the servo stop when the PIR is activated, then restart when the charge falls back to 0? I've looked over a lot of places and tried a few things but nothing seems to work.
- Franklin97355
Re: How can I make a servo stop when a pin is High?
Start by showing your code so we can see what you have so far. It would also help if you drew up a picture/schematic of your circuit.
- zinc55
Alright, here's the code http://BANNED.com/JT656Wnw
The wiring is a bit to complex to take a picture of, but everything other than the common of the PIR (pin 2) and the output led (pin 4) is on the breadboard.
- philba
well, fer starters, you are testing against the value of the variable inputPin - that will always be 2. You seem to be confused between the pin number and the value read from that pin though later you actually read the pin.
