Atmoduino - Ambilight for the masses
Re: Atmoduino - Ambilight for the masses
by scorpie on Wed Nov 07, 2012 1:57 pm
]copy and past the text above in a textfile and name it atmoduino.ino. thats it
or use this one, its working for me with the lpd8806 chips
[attachment=0]AtmoDuino.txt[/attachment
AtmoDuino.txt
rename to ino
(1.49 KiB) Downloaded 175 times
scorpie
by demmax2004 on Fri Nov 30, 2012 3:37 am
Only Windows users.
The best for Windows.
Adalight supported in the Server IR 2.0.9 Ambilight Edition, all the details HERE
demmax2004
by demmax2004 on Mon Dec 10, 2012 9:24 am
added wizard zones
Video HERE
demmax2004
by demmax2004 on Thu Aug 29, 2013 5:41 am
AmbiBox 2.1.4 support Atmoduino
demmax2004
by Schicksal on Wed Nov 06, 2013 4:19 am
Can someone pls post a working FastSPI for lpd8806?
My stripes don't light um and do nothing.
------------edit-------------
done.
my stripes lights up like they should.
the colours are correct (had to change the RGB order).
now sometimes some LEDs lights up in total blue. just like lightnings. only a mini part of a second
then everything ist ok for a while and then again somewhere else. sometimes on the left side, sometimes on the right side.
any idea?
should i play with the datarate or anything else? perhaps some settings in atmowin or the mediaportal plugin?
Schicksal
by olli123 on Mon Dec 02, 2013 5:19 am
Hi there,
i´m playing around with a WS2801 32 LED stripe and Arduino Uno.
Target: Use AtmoWin with Atmoduino!!!
Problem: Test Leds Programm is running fine, no problems.......
Trying tu run Atmoduino on the Arduino brings up the problem.
Frist the LEDs stay dark. After playing around with it i found out that changing the Com port speed to 9600baud brings changes. With different speed the LEDs are flickering around.
When i use the color changer mode in AtmoWin i see some leds going on showing colours some leds stay out.
Yesterday only the first 5 Leds turns on and the rest 27 Leds stay dark.
So i see that the stripe is reacting to the controll commands but it does not do the correct display of the color.
When switching the AtmoWin mode to Static color the stripe freeze but does not display the static color...........
So i think there is a problem with the data transfer between the PC and the Arduino Com Port.
Do anybody know about that problem? What can i do to get it to work correctly?
olli123
by Schicksal on Thu Jan 09, 2014 2:01 am
Is anyone using more than 150 LEDs with an arduino uno?
Schicksal
by demmax2004 on Thu Jan 09, 2014 3:11 am
Schicksal wrote:Is anyone using more than 150 LEDs with an arduino uno?
nobody, very slow
demmax2004
by Schicksal on Thu Jan 09, 2014 6:11 am
i've got colourflashes on my last stripe. could an arduino mega solve this problem because of its bigger memory?
-----edit------
my arduino is now working perfectly with 166 LEDs. (Arduino Uno R3, Code written for fastspi_led2 of Ollie123(here and MediaPortal Forum) and atmowin mod of angie05(MediaPortal Forum) with MediaPortal)
Schicksal
