Creating a SoftwareSerial object array
Postby roherman00 » Thu Apr 26, 2012 6:10 pm
I have been searching the internet and asked on Robotshop forum but have not solved this issue yet. Is it possible to make an array of SoftwareSerial objects such as:
SoftwareSerial softSerial[2] = { SoftwareSerial(2, 3), SoftwareSerial(4, 5) }
It compiles and uploads fine but only the softSerial[1] returns or sends an serial data and softSerial[0] always returns 0. I'm confused because I saw this code:
LED led[5] = { LED(1), LED(2), ... LED(5) } and it works
For example led[4].on() will turn on an led and
softSerial[1].write("hello") will send hello but
softSerial[0].write("hello") sends nothing and returns a 0
I know both serial devices work because if I swap them in the array the other serial device now sends data, but it is always the first instantiation (i.e. softSerial[0]) that does not seem to exist.
Thank you to anyone who has an idea
roherman00
Re: Creating a SoftwareSerial object array
Postby adafruit_support_bill » Fri Apr 27, 2012 5:29 am
SoftwareSerial can only receive on one port at a time. By default, the last port you initialize is enabled for receive. To receive on the other port you must explicitly enable it with the "listen()" function.
http://arduino.cc/en/Tutorial/TwoPortReceive
Not sure why it wouldn't send though...
Postby roherman00 » Fri Apr 27, 2012 7:02 am
Thank you very much. I'm glad that it is an easy solution. To be honest I'm sure it sent data but because it returned 0 on a receive I figured it wasn't doing either. Just a couple of questions. Yes or no answers are cool with me.
1) If I write for example softSerial[1].write(some number) and then the next line is softSerial[0].listen() would the next line be softSerial[0].write(some number)? If I use listen() does it automatically stop listening to the other?
2) Can you do softSerial[0].listen().write(some value)
3) I assume from what you wrote that if I'm only writing data either port can do that but once I want to listen I have to attach a listen() argument to the softSerial that I want?
4) Adding on to 3 it says arduino can do multiple softSerial ports so to listen to any of them I just swap listen() arguments?
Again thanks alot for the help.
roherman00
Postby adafruit_support_bill » Fri Apr 27, 2012 7:40 am
1. not sure I understand the whole question, but to the last part: yes. Calling listen() on one port causes it to stop listening on any other SoftwareSerial port. (Regular hardware serial ports are not affected)
2. no - it is two separate statements.
3. yes. You can write to any port at any time. But you need to explicitly listen on a port before it can receive data.
4. yes. The trick is knowing when to listen to which port. Since there is no buffering on the non-listening ports, any data received on a port while not listening will be lost.
Postby roherman00 » Fri Apr 27, 2012 7:49 am
1) I was just giving some poor example of code
softSerial[1].write("hello") //the last instantiation of softSerial made
softSerial[0].listen(); //listen to the first instantiation now
softSerial[0].write("hello");
softSerial[0].read();
Oh now I see why my question was confusing because I just remembered you mentioning that you do not need to listen to a port to be able to write.
4) Thanks for mentioning that I'll keep that in mind. If I did not know that I would probably have another major issue in a day or two.
I can't wait to try it out now. Thank you for the help.
roherman00
Return to Arduino
Users browsing this forum: TripleT and 10 guests
New Products [103]
LEDs[109]
Cables[61]
