Arduino ethernet board programming fails: avrdude resp=00
Postby dg12 » Tue May 01, 2012 12:04 pm
Received arduino ethernet board.
Attempts to program it om Mac lion with Arduino 1.0.1rc2 via FTDI cable
report:
"         Using Port                    : /dev/tty.usbserial-FTFO9AFU
        Using Programmer              : arduino
        Overriding Baud Rate          : 57600
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [00]
avrdude: stk500_getsync(): not in sync: resp=0x00"
Monitor at 9600 reports "Reset done."
It's talking to the Ethernet port, What is it doing?
I have attempted to reflash boot loader for optiLoader as per
http://arduino.cc/en/Main/ArduinoBoardEthernet reference to
http://scuola.arduino.cc/en/content/upg ... st-version
but that does not compile!
In file included from optiLoader.cpp:45:
optiLoader.h:6: error: 'byte' does not name a type
optiLoader.h:7: error: 'byte' does not name a type
optiLoader.h:8: error: 'byte' does not name a type
In file included from ... arduino/cores/arduino/Arduino.h:213,
                from optiLoader.cpp:67:
... arduino/variants/standard/pins_arduino.h:41: error: expected
unqualified-id before numeric constant
... arduino/variants/standard/pins_arduino.h:42: error: expected
... arduino/variants/standard/pins_arduino.h:43: error: expected
and several more.
1) How can I program this board?
2) What is it running to the ethernet port?
3) can it be programmed from the ethernet port?
dg12
Re: Arduino ethernet board programming fails: avrdude resp=00
Postby adafruit_support_bill » Tue May 01, 2012 12:21 pm
Make sure you have the correct board type and COM port selected.
Hold the shift key down while pressing the upload button and post the diagnostic output.
Postby dg12 » Tue May 01, 2012 12:30 pm
Arrgh! So easy! I forgot to select etherboard. :oops:
Thank you.
Might you add a sticker to the board with a version number of the bootloader installed?
dg12
Postby dg12 » Tue May 01, 2012 12:37 pm
Just to mention,
After successfully programing the ethernet board.
I uploaded again holding down shift while clicking on upload and got:
avrdude: Yikes!  Invalid device signature.
         this check.
Click upload without shift works.
again clicking upload with shift works, no additional output.
dg12
Return to Arduino
Users browsing this forum: No registered users and 12 guests
New Products [113]
Raspberry Pi[81]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
