Rotary Encoder and 4wd bot
Postby talasyn » Fri May 11, 2012 1:48 pm
Hello all,
I'm quite the noob but am excited about trying to build a 4wd / mecanum-wheeled robot. I've seen talk about the need to use encoders with such a project. Sadly, I'm really not sure logically how to make use of the encoders in my arduino code. I'm guessing the purpose of them for a 4wd is to make sure the wheels turn at exactly the same rate of speed? Would someone be so kind as to explain this and perhaps how this is implemented in code?
Todd
talasyn
Re: Rotary Encoder and 4wd bot
Postby adafruit_support_bill » Sat May 12, 2012 8:15 am
Encoders are used for monitoring both speed and distance. There are various types and the coding specifics will depend on which type you choose to use. In general, to keep a 4-motor 4wd vehicle going straight, you will use the encoder output as feedback to the motor control to keep all of them at the desired speed.
Return to Arduino
Users browsing this forum: vmax77 and 11 guests
New Products [102]
LEDs[109]
Cables[60]
