help me, something wrong with my output (pwm arduino)
Postby haneys » Thu May 31, 2012 12:11 pm
Hi.. I need help.. i have the coding as shown below, but its not working as what i expected.. base on what i know, the coding below should provide me a 2MHz frecuency at output pin 9 and 1kHz at ouput pin 8.. but when i test it with oscilloscope i only obtain 2kHz at output pin 9.. what should i do to obtain 2MHz at output pin 9?? how can i change/modified the code?? many2 thankz..
#include <util/delay.h>
int rog = 8;
  pinMode(9, OUTPUT);
  pinMode(rog, OUTPUT);
  TCCR1A = 0;
  TCCR1B = 0;
  TCCR1A |= _BV(WGM11) | _BV(COM1A1);
  TCCR1B |= _BV(WGM12) | _BV(WGM13) | _BV(CS10) | _BV(ICNC1);
  ICR1= 7;
  OCR1A = 3;
void loop(){
delayrog();
void delayrog(){
   while (1)
  digitalWrite(rog, HIGH);
  _delay_ms(0.52);
  digitalWrite(rog, LOW);
  _delay_ms(0.52);
haneys
Re: help me, something wrong with my output (pwm arduino)
Postby adafruit_support_rick » Thu May 31, 2012 1:59 pm
Looks right to me. I'm getting 2MHZ from your code on a Uno
What processor are you running? Are you sure your CPU is running at 16MHz?
Are you sure you're reading your scope correctly?
Postby haneys » Thu May 31, 2012 10:23 pm
really? then how can i make sure i run my cpu at 16MHz?
i can get 2Mz at output pin 9 when i only use the first code below, but when i add up another output at pin 8 i wont get 2Mz at output pin 9.. i found this weird.. help me..
without output at pin 8:
  pinMode(9, OUTPUT);
  TCCR1A = 0;
  TCCR1B = 0;
  ICR1= 7;
  OCR1A = 3;
void loop(){
having output at pin 8:
int rog = 8;
  pinMode(9, OUTPUT);
  TCCR1A = 0;
  TCCR1B = 0;
  ICR1= 7;
  OCR1A = 3;
void loop(){
delayrog();
void delayrog(){
   while (1)
  _delay_ms(0.52);
  _delay_ms(0.52);
haneys
Postby pburgess » Thu May 31, 2012 10:35 pm
Perhaps DigitalWrite() is playing dirty pool with the PORT/PIN registers. Try using direct PORT manipulation and see if that helps: tutorial on Arduino.cc site.
pburgess
Postby haneys » Thu May 31, 2012 11:56 pm
Did u mean like this? still wont work.. :(
#include <avr/io.h>
#define F_CPU 16000000UL //set 16mhz crystal
int rog = 8;
float rogdelay = 0.6;
  pinMode(9, OUTPUT);
TCCR1A = 0;
  TCCR1B = 0;
  ICR1= 7;
  OCR1A = 3;
//  OCR2B = 3;
void loop(){
delayrog();
DDRB |=0b00001010; //set pin mana jadi output
   PORTB = 0b00000000;
               PORTB = 0b00000001 ;
      _delay_ms(0.52);
      PORTB = 0b00000000 ;
      _delay_ms(0.52);
haneys
Postby adafruit_support_rick » Fri Jun 01, 2012 9:08 am
I think it's more likely that _delay_ms is doing something with the timer. None of the standard arduino library implementations seem to use any timers, but maybe you've got some other toolchain?
As I said, I ran the exact code you posted on a Uno with Arduino 1.0.1, and I'm getting 2MHz on Pin 9. I'm getting about 947Hz on pin 8.
BTW - you don't need to set _BV(ICNC1) in TCCRB1, since you're not using input capture. Anyway, input capture is disabled when you set pin 9 to output.
Return to Arduino
Users browsing this forum: No registered users and 7 guests
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
