Hello, this is my first post on this forum so please forgive (some of) my ignorance.
I've been using the Arduino UNO R2 for about two weeks now, it's awesome.
I want to make this: http://www.niklasroy.com/project/101/PING
I have all the parts, the only last hurdle is that i want to use the Arduino as an ISP to program this : http://niklasroy.com/codes/ping.txt onto an Atmega8-16PU.
It's probably very easy, but i've been searching for days now and can't seem to find it. Every answer brings more questions.
All i can find are tutorials on howto burn the Arduino bootloader and then add Arduino code to it.
So can anyone give me a step by step tutorial on how to do this?
Arduino PING!
- Franklin97355
Re: Arduino PING!
Have you looked at this? http://arduino.cc/en/Tutorial/ArduinoISP
- tapijtklopper
Re: Arduino PING!
Yes, but isn't that just to burn the Arduino bootloader?
I also found this: http://arduino.cc/en/Tutorial/ArduinoToBreadboard
But from what i can understand both are meant for Arduino programming or migration.
I need to program C code onto the Atmega8. Which method is the correct one?
Also, is the Atmega8-16PU a raw chip? Does it need another kind of bootloader?
- tapijtklopper
Re: Arduino PING!
I've tried to use the c code on Arduino 1.0.1
I copy/paste it and click Verify but it give me the following messages.
sketch_jun17a.cpp: In function 'int main()':
sketch_jun17a:92: error: 'GICR' was not declared in this scope
Any idea on what's wrong.
PING runs on an ATMEGA8 with 16MHz, program is written in AVR-GCC
* "THE BEER-WARE LICENSE" (Revision 42):
* <niklasroy.com> wrote this file. As long as you retain this notice you
* can do whatever you want with this stuff. If we meet some day, and you think
* this stuff is worth it, you can buy me a beer in return Niklas Roy
As usual:
Sorry for too less coments and crappy coding skills
#include <avr/io.h>
#include <stdint.h>
#include <stdlib.h>
#include <util/delay.h>
#include <math.h>
#include <avr/interrupt.h>
volatile uint8_t ping_graphics[8][19]={
{1,1,1,1,0,1,0,1,1,1,1,0,1,1,1,1,0,1,0},
{1,0,0,1,0,0,0,1,0,0,1,0,1,0,0,0,0,1,0},
{1,0,0,1,0,1,0,1,0,0,1,0,1,0,0,0,0,1,0},
{1,1,1,1,0,1,0,1,0,0,1,0,1,0,1,1,0,1,0},
{1,0,0,0,0,1,0,1,0,0,1,0,1,0,0,1,0,1,0},
{1,0,0,0,0,1,0,1,0,0,1,0,1,0,0,1,0,0,0},
{1,0,0,0,0,1,0,1,0,0,1,0,1,1,1,1,0,1,0},
{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
volatile uint8_t subtext_graphics[6][72]={
// A U G M E N T E D P I X E L
{0,1,1,1,1,0,1,0,0,1,0,1,1,1,1,0,1,1,1,1,1,0,1,1,1,1,0,1,1,1,1,0,1,1,1,1,1,0,1,1,1,1,0,1,1,1,0,0,0,0,1,1,1,1,0,1,0,1,0,0,1,0,1,1,1,1,0,1,0,0,0,0},
{0,1,0,0,1,0,1,0,0,1,0,1,0,0,0,0,1,0,1,0,1,0,1,0,0,0,0,1,0,0,1,0,0,0,1,0,0,0,1,0,0,0,0,1,0,0,1,0,0,0,1,0,0,1,0,1,0,1,0,0,1,0,1,0,0,0,0,1,0,0,0,0},
{0,1,1,1,1,0,1,0,0,1,0,1,0,1,1,0,1,0,1,0,1,0,1,1,1,0,0,1,0,0,1,0,0,0,1,0,0,0,1,1,1,0,0,1,0,0,1,0,0,0,1,1,1,1,0,1,0,0,1,1,0,0,1,1,1,0,0,1,0,0,0,0},
{0,1,0,0,1,0,1,0,0,1,0,1,0,0,1,0,1,0,1,0,1,0,1,0,0,0,0,1,0,0,1,0,0,0,1,0,0,0,1,0,0,0,0,1,0,0,1,0,0,0,1,0,0,0,0,1,0,1,0,0,1,0,1,0,0,0,0,1,0,0,0,0},
{0,1,0,0,1,0,1,1,1,1,0,1,1,1,1,0,1,0,0,0,1,0,1,1,1,1,0,1,0,0,1,0,0,0,1,0,0,0,1,1,1,1,0,1,1,1,0,0,0,0,1,0,0,0,0,1,0,1,0,0,1,0,1,1,1,1,0,1,1,1,1,0},
{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
// 1 1 2 3 4 5 6 7
// 0 0 0 0 0 0 0
float slow_count=0;
float sin_result;
float sin_result2;
volatile uint8_t sin_shift=0;
volatile uint8_t scroll_count;
volatile uint16_t video_line=0;
volatile uint8_t ball_x=20; //0-110
volatile uint16_t ball_y=100; //50-290
volatile int8_t speed_x=1;
volatile int8_t speed_y=2;
volatile uint8_t obstacle[]={0,0,0,0,0,0,0,0};
volatile uint8_t end_of_image=0;
volatile uint8_t display_thresh=0;
volatile uint8_t start_screen=1;
int8_t ball_direction;
int8_t beep_cycle=0;;
//////////////////////////////////////////////////////////////// MAIN /////////////////////////////
int main(void)
//IO
DDRB = 0b00000010; // b1:sound output
DDRC = 0b00000001; // c0:via 1k to video signal
DDRD = 0b00000000; // d2,d3 sync signal inputs
//Pull Up's / Outputs
PORTB= 0b00000000; //
PORTC= 0b00000000; //
PORTD= 0b00100000; // d5:button
TCCR1A=0b01000000; // configure pwm output on pb1 (sound)
TCCR1B=0b00001011;
MCUCR=0b00000110; //INT0 & INT1 generate interrupt requests
GICR= 0b11000000; //hardware interrupt INT0&1 enable
sei(); //switch on global interrupts
while(1)
if (end_of_image){ //will be executed when whole image is drawn
end_of_image=0;
if ( PIND & (1<<5 ) ) { //check button
display_thresh=0; //no button pushed
}else{
display_thresh++; //button pushed
if (display_thresh>25)display_thresh=25;
start_screen=0;
TCCR1A=0b10000001; // configure pwm output on pb1 (sound)
TCCR1B=0b00000010;
if(start_screen){ //calculate start screen animation
scroll_count++;
slow_count++;
sin_result=slow_count;
sin_result/=16;
sin_result=sin(sin_result);
sin_result+=1;
sin_result*=60;
sin_result2=slow_count*10;
sin_result2=sin(sin_result2);
sin_result2+=1;
sin_result2*=5;
sin_shift=sin_result;
OCR1A=(sin_result+sin_result2)*8+20; //sound at start animation
TCNT1=0;
}else{ //no start screen: calculate game logics instead
uint8_t max_val=0;
uint8_t max_pos=10;
for (uint8_t i=0;i<8;i++){ //find darkest obstacle
if(obstacle[i]>max_val){
max_val=obstacle[i];
max_pos=i;
OCR1A=OCR1A>>1; //switch off previous sound
switch (max_pos){ //new direction is opposite from darkest obstacle
case 4:
speed_x=-1;
speed_y=-2;
OCR1A=21; //sound
break;
case 5:
speed_x=0;
speed_y=-2;
OCR1A=22; //sound
break;
case 6:
speed_x=1;
speed_y=-2;
OCR1A=23; //sound
break;
case 7:
speed_x=1;
speed_y=0;
OCR1A=24; //sound
break;
case 0:
speed_x=1;
speed_y=2;
OCR1A=25; //sound
break;
case 1:
speed_x=0;
speed_y=2;
OCR1A=26; //sound
break;
case 2:
speed_x=-1;
speed_y=2;
OCR1A=27; //sound
break;
case 3:
speed_x=-1;
speed_y=0;
OCR1A=28; //sound
break;
//move ball
ball_x+=speed_x;
if (ball_x==255){ //ball out left
ball_x=93;
}else if(ball_x>93){ //ball out right
ball_x=0;
ball_y+=speed_y;
if (ball_y>275) { //bounce bottom
speed_y=-2;
ball_y=275;
OCR1A=33; //sound
if (ball_y<65) { //bounce top
speed_y=2;
ball_y=65;
OCR1A=33; //sound
for (uint8_t i=0;i<8;i++){ //reset obstacle detection
obstacle[i]=0;
ISR(INT1_vect) // interrupt routine - new video image
video_line=0;
ISR(INT0_vect) // interrupt routine - new video line
video_line++;
uint16_t temp_video_line=video_line;
uint8_t temp_ball_x=ball_x;
uint16_t temp_ball_y=ball_y;
uint8_t temp_top_left_obstacle=obstacle[0];
uint8_t temp_top_mid_obstacle=obstacle[1];
uint8_t temp_top_right_obstacle=obstacle[2];
uint8_t temp_right_obstacle=obstacle[3];
uint8_t temp_bot_right_obstacle=obstacle[4];
uint8_t temp_bot_mid_obstacle=obstacle[5];
uint8_t temp_bot_left_obstacle=obstacle[6];
uint8_t temp_left_obstacle=obstacle[7];
uint8_t i;
if (start_screen){//------------------------------------------------ start screen
if (temp_video_line>=45&&temp_video_line<230){
_delay_us(16);
uint8_t screen_y=(temp_video_line-45-sin_shift)/8;
if (screen_y>7)screen_y=7;
for (uint8_t i=0;i<19;i++){
PORTC=ping_graphics[screen_y][i]; //draw 'PING'
}else if (temp_video_line>230&&temp_video_line<260){
_delay_us(2);
uint8_t screen_y=(temp_video_line-230)/4;
if (screen_y>5)screen_y=5;
for (uint8_t i=0;i<50;i++){
PORTC=subtext_graphics[screen_y][i]; //draw 'AUGMENTED'
}else if (temp_video_line>260&&temp_video_line<290){
_delay_us(2);
uint8_t screen_y=(temp_video_line-260)/4;
_delay_us(12.5);
for (uint8_t i=50;i<72;i++){
PORTC=subtext_graphics[screen_y][i]; //draw 'PIXEL'
}else if (temp_video_line==290){
end_of_image=1;
}else{//------------------------------------------------------------ normal_game
if(temp_video_line>60&&temp_video_line<290){
if(temp_video_line<65){ //top playfield line
_delay_us(4.5);
PORTC=0b00000001;
_delay_us(41);
_delay_us(.5);
PORTC= 0b00000000;
}else if(temp_video_line>285){ //bottom playfield line
_delay_us(4);
PORTC=0b00000001;
_delay_us(41);
_delay_us(.5);
PORTC= 0b00000000;
}else if(display_thresh>24){ //display brightnes threshold for adjustment
_delay_us(2);
for (i=0;i<74;i++){
if ((ACSR&(1<<ACO ))){
PORTC=0b00000001;
_delay_us(.1);
PORTC= 0b00000000;
PORTC=0b00000000;
}else if (temp_video_line>temp_ball_y-5&&temp_video_line<temp_ball_y+15){//draw ball and capture brightnes of surrounding area
if (temp_video_line<temp_ball_y){ //capture video lines on top of ball
_delay_us(1.2);
for (i=0;i<temp_ball_x;i++)_delay_us(.1);
PORTC=0b00000010;_delay_us(.1);PORTB= 0b00000000;
if ((ACSR&(1<<ACO )))temp_top_left_obstacle+=2; //capture brightnes top left of ball
_delay_us(.1);
if ((ACSR&(1<<ACO )))temp_top_mid_obstacle+=2; //capture brightnes top of ball
_delay_us(.1);
if ((ACSR&(1<<ACO )))temp_top_right_obstacle+=2; //capture brightnes top right of ball
if (temp_video_line>temp_ball_y&&temp_video_line<temp_ball_y+10){ //ball video lines
_delay_us(.8);
if ((ACSR&(1<<ACO )))temp_left_obstacle++; //capture brightnes left of ball
PORTC=0b00000001; //draw ball
_delay_us(.5);
if ((ACSR&(1<<ACO )))temp_right_obstacle++; //capture brightnes right of ball
PORTC= 0b00000000; //no ball anymore
if (temp_video_line>temp_ball_y+10){ //video lines below ball
PORTC=0b00000010;_delay_us(.1);PORTC= 0b00000000;
if ((ACSR&(1<<ACO )))temp_bot_left_obstacle+=2; //capture brightnes top left of ball
_delay_us(.1);
if ((ACSR&(1<<ACO )))temp_bot_mid_obstacle+=2; //capture brightnes top of ball
_delay_us(.1);
if ((ACSR&(1<<ACO )))temp_bot_right_obstacle+=2; //capture brightnes top right of ball
}else if(temp_video_line==290){end_of_image=1;}
//update volatiles
obstacle[0]=temp_top_left_obstacle;
obstacle[1]=temp_top_mid_obstacle;
obstacle[2]=temp_top_right_obstacle;
obstacle[3]=temp_right_obstacle;
obstacle[4]=temp_bot_right_obstacle;
obstacle[5]=temp_bot_mid_obstacle;
obstacle[6]=temp_bot_left_obstacle;
obstacle[7]=temp_left_obstacle;
- Franklin97355
Re: Arduino PING!
Where is GICR defined? Probably in one of the includes but are you sure?
Re: Arduino PING!
looks like you're not compiling for the right chip. GICR is a register on the mega8. if you had the correct board type selected it should compile. on my arduino 1.01 arduino ng with atmega8 is the very last board in the list. try that.
Re: Arduino PING!
aw, shoot. someone really ought to filter my posts for stupid...
you've got other problems.
arduino defines its own main routine. you'll have to put your code into loop(). i believe that arduino also supplies isr's for int0 and int1, so you'll have to use attachInterrupt() in order to get your code linked to those routines. consult the arduino reference for how that works.
best idea, though, is to not use arduino at all and compile with avr-gcc since that's what the program is written for.
you can still use arduinoisp to upload to your project. you'll need to locate the correct fuse settings, or you'll find that your project is running at about 1MHz instead of 16MHz. the information you need may be on the page on which you found the project. maybe there's a Makefile as well.
- tapijtklopper
Re: Arduino PING!
Thanks for the reply.
This is turning out to be a lot harder than i imagined, a lot of technical jargon that i'm trying to learn, not giving up though.
So please excuse me for still trying with the Arduino. Could i just opload the Arduino ISP to my Arduino board and then select in the Board menu "Arduino NG or older w/ ATmega8" as the chip to program?
Like this picture shows: http://arduino.cc/en/uploads/Tutorial/arduinoispNG.png
Wouldn't that give me the correct fuse settings?
Re: Arduino PING!
not without rewriting the code. it's not an arduino sketch. arduino supplies it's own main function, so you can't have main in your code. arduino requires functions called setup and loop, neither of which are defined in the code you've provided. arduino provides isrs for int0 and int1, so there may be a conflict with your code. could be a world of other problems, too. i took only a cursory look.Tapijtklopper wrote:So please excuse me for still trying with the Arduino. Could i just opload the Arduino ISP to my Arduino board and then select in the Board menu "Arduino NG or older w/ ATmega8" as the chip to program?
your best bet will be to compile the code with avr-gcc and upload using arduino-isp and avrdude. i didn't see a Makefile on the page you linked to, but maybe i just missed it.
Re: Arduino PING!
your best bet will be to compile the code with avr-gcc and upload using ArduinoISP and avrdude. i didn't see a Makefile on the page you linked to, but maybe i just missed it.
the fuse settings are shown in one of the photos on the project page. high fuse = 0xdf and low fuse = 0xef. again, it is probably simplest to use ArduinoISP and avrdude.
- tapijtklopper
Re: Arduino PING!
This is just a world of hurt man, i've been reading books of text to get this done. So far i've managed to opened the ping.txt file in Programmer's Notepad. I've told it it's C code and then i go to Tools and click WinAVR Make All. All it does is give me this error message.
( > "make.exe" all make.exe *** No rule to make
target `all'. Stop > Process Exit Code: 2 > Time taken: 00:08)
I can't figure out how to compile this. Let alone upload this to the Atmega8.
Can anyone prep the files for me and just give me a step by step tutorial?
Re: Arduino PING!
you need a Makefile. apparently winavr uses a program called MFile to generate makefiles. give it a try.
- tapijtklopper
Re: Arduino PING!
So i asked and got a .hex file from the guy who programmed it. Sadly no makefile.
But i think i can do this without a makefile. (or am i spacing on this one?)
And i think i finally know the rundown.
Here we go:
Flash the Arduino UNO with the ArduinoISP sketch on it.
Make a folder with the ping.hex file in it and a ping.bat with the following in it
avrdude -c arduino -p m8 -P usb -U flash:w:ping.hex
Connect the Arduino UNO to the Atmega8-16PU you need to program like this: http://arduino.cc/en/uploads/Tutorial/BreadboardAVR.png
Connect the Arduino UNO to the usb port and doubleclick the ping.bat file and it should start up avrdude and execute everything within a few seconds.
Is this the correct approach?
Here we go:
Re: Arduino PING!
more like :
where COMwhatever is whichever COM port your arduino show up as.
if you have not yet burned your fuses, you will likely be disappointed since the mega8 will be running at 1 MHz.
these are the values i got from the project page you referenced. you might want to locate a fuse calculator and do a little sanity check before burning them because getting them wrong can effectively brick your chip.
have a look at ladyada's avr programming tutorial.
avrdude -c avrisp -p m8 -P COMwhatever -U flash:w:ping.hex
avrdude -c avrisp -p m8 -P COMwhatever -U hfuse:w:0xdf:m -U lfuse:w:0xef:m
- tapijtklopper
Re: Arduino PING!
Ok, so by using this i got the same results.
[url]http://www.frank-zha%20o.com/fusecalc/fusecalc.php?chip=atmega8&LOW=EF&HIGH=DF&LOCKBIT=FF[/url]
So i need to run this first
(Adafruit says when using USB no -P is needed)
And then use
Right?
avrdude -c avrisp -p m8 -U hfuse:w:0xdf:m -U lfuse:w:0xef:m
And then use
