Is there any difference between the bootloader from an Arduino UNO and one that was uploaded to a BoArduino using the "Diecimila/Duemilanove with 328P" setting on the IDE and an FTDI Friend?
I've moved a 328P from my Uno to a BoArduino. When I go to upload a sketch, I get the following error:
"avrdude: stk500_getsync(): not in sync: resp=0x00"
Would using the "Diecimila/Duemilanove with 328P" settings and reloading the bootloader on the chip while it is in the BoArduino resolve this? Or, am I barking up the wrong tree?
UNO vs. BoArduino Bootloader
- adafruit_support_bill
Re: UNO vs. BoArduino Bootloader
The "Board Type" has more to do with the bootloader than the name printed on the board. When you plug a chip with an UNO bootloader into a Boarduino (Duemilanove, Deicemila, etc) that board effectively becomes an UNO for the purposes of uploading.
So I could in theory put the UNO bootloader on the chip and use it in a BoArduino as long as I select UNO instead of Diecimila/Duemilanove for the settings before I upload?
(Sorry for the delayed response, I'm currentyl in a sand-overrun location that you ship to for free)
That's right.So I could in theory put the UNO bootloader on the chip and use it in a BoArduino as long as I select UNO instead of Diecimila/Duemilanove for the settings before I upload?
