Running two motors
Running two motors
by garethpletts on Wed Nov 07, 2012 9:58 pm
Im relatively new to Arduino so would greatly appreciate some code advice.
I need to run two DC Motors using the Adafruit motor shield. I need to run one motor forward on M1 for 2450, then run another motor on M2 after M1 for 2600, then stop both of them for 30000, then repeat again.
I have managed to work out how to do one motor on its own (as shown below), but I cant work out how to run two motors as mentioned.
AF_DCMotor motor1 (1, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Motor test!");
  motor.setSpeed(255);     // set the speed to 200/255
  Serial.print("tick");
  motor.run(FORWARD);      // turn it on going forward
  delay(2450);
  Serial.print("tack");
  motor.run(RELEASE);      // stopped
  delay(30000);
Does anyone know how this would be done?
Many thanks :)
garethpletts
Re: Running two motors
by adafruit_support_bill on Thu Nov 08, 2012 7:09 am
The code you posted won't work. In fact it won't even compile. If you define your motor as "motor1" you have to use "motor1" in all the commands.
If you want to run 2 motors, you have to define 2 motors:
AF_DCMotor motor1 (1, MOTOR12_64KHZ); // create motor #1, 64KHz pwm
AF_DCMotor motor2 (1, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
When you want to run motor 1 you use "motor1" commands.
When you want to run motor 2 you use "motor2" commands.
