help with sketch
Re: help with sketch
by tldr on Sun Nov 11, 2012 1:32 am
nate21 wrote:im still getting a error on line 27 int TempSet=85, tempreset=83; the error is expected primary expression before int
that message usually indicates an improperly terminated statement in a previous line. that would probably be the fault of your incomplete declarations of the lcd and temp sensor.
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
tldr
by jigsawnz on Sun Nov 11, 2012 2:25 am
this compiles but wont work. Pin 8 and pin 4 are being used for activating relays and for the LCD. You will need to change the Pins around.
I knew the code looked familiar. http://www.420magazine.com/forums/do-yourself/153079-arduino-based-room-controller.html I used the same code when I first tried to build an egg incubator.
// Lesson 4.5 Adding output, Relays etc. with hysterisis
#include "DHT.h"
#include <LiquidCrystal.h>
#include <Wire.h>
#define DHTPIN 2     // what pin we're connected to
#define tempcontpin 8   //temp output to control
#define humcontpin 4    //humidity output to control
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
int maxF=0, minF=212;
int maxH=0, minH=100;
LiquidCrystal lcd(8,9,4,5,6,7);
DHT dht(DHTPIN, DHTTYPE);
//here's where the temp and hum setpoints are changed
int tempset=85, tempreset=83;
int humset=55, humreset=53;
int tmem=0, hmem=0;
  Serial.begin(9600);
  Serial.println("DHTxx test!");
  dht.begin();
  lcd.begin(20, 4); // Set the display to 20 columns and 4 rows
  lcd.clear();
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  float tF= (t* 1.8) +32; //convert to Farenheit
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h)) {
    Serial.println("Failed to read from DHT");
  else {
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
    Serial.print(tF);
    Serial.println(" *F");
    lcd.setCursor(0,0);
    lcd.print("Temp ");
    lcd.print(tF);
    lcd.write(B11011111); // print degree symbol
    lcd.print("F ");
    lcd.setCursor(20,0);
    lcd.print("Hum ");
    lcd.print(h);
    if (tF>maxF) {
      maxF=tF;
    }  //check for max temp
    if (tF<minF) {
      minF=tF;
    }  //check for min temp
    lcd.setCursor(0,1);
    lcd.print("H=");
    lcd.print(maxF);
    lcd.print("F L=");
    lcd.print(minF);
    lcd.print("F ");
    if (h>maxH)  {
      maxH=h;
    }  //check for max hum
    if (h<minH)  {
      minH=h;
    }  //check for min hum
    lcd.setCursor(20,1);
    lcd.print("max=");
    lcd.print(maxH);
    lcd.print(" min=");
    lcd.print(minH);
    //Here's the section for control with hysterisis
    if (tempreset<=tF && tF<=tempset && tmem==1) {
      digitalWrite (8, HIGH);
     if (tF>=tempset) {
      tmem==1,
     if (tF<tempreset)  {
      tmem==0,
      digitalWrite (8, LOW);
    if (humreset<=h && h<=humset && hmem==1) {
      digitalWrite (4, HIGH);
     if (h>humset) {
      hmem==1,
    if (h<humreset) {
      hmem==0,
      digitalWrite (4, LOW);
A person only needs two things in life. Some CRC/WD40 to make things go and some duct tape to make things stop.
jigsawnz
by nate21 on Sun Nov 11, 2012 1:03 pm
thank you thats what i need im having a hard time learning code
nate21
by nate21 on Sat Nov 17, 2012 8:53 pm
i am using pin 8 to control temp and pin 9 to control humidity im using leds to test i can only get the outputs to turn on if i lower tempset and humset down very low i hope im posting the code corectly
 //4.5 Adding output, Relays etc. with hysterisis
#include "DHT.h"
#include <Wire.h>
#define DHTPIN 7    // what pin we're connected to
#define humcontpin 9    //humidity output to control
LiquidCrystal lcd(12,11,10,5,4,3,2);
int backLight = 13;
int tempset=99, tempreset=98;
int humset=99, humreset=98;
int tmem=0, hmem=0;
  Serial.begin(9600);
  dht.begin();
  pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH);
  lcd.clear();
  else {
    Serial.print(h);
    Serial.print(t);
    Serial.print(tF);
    lcd.setCursor(0,0);
    lcd.print("Temp ");
    lcd.print(tF);
    lcd.print("F ");
    lcd.setCursor(10,0);
    lcd.print("Hum ");
    lcd.print(h);
    if (tF>maxF) {
      maxF=tF;
    if (tF<minF) {
      minF=tF;
    lcd.setCursor(0,1);
    if (h>maxH)  {
      maxH=h;
    if (h<minH)  {
      minH=h;
    lcd.setCursor(0,1);
    lcd.print("tempset");
    lcd.print(tempset);
    lcd.print("humset");
    lcd.print(humset);
    lcd.print("%");
      pinMode(tempcontpin, OUTPUT);
     if (tF>=tempset) {
      tmem==1,
     if (tF<tempreset)  {
      tmem==0,
      pinMode(humcontpin,OUTPUT);
      digitalWrite (9, HIGH);
     if (h>humset) {
      hmem==1,
    if (h<humreset) {
      hmem==0,
      digitalWrite (9, LOW);
nate21
by jigsawnz on Sat Nov 17, 2012 10:03 pm
Out of curiosity, whats your project. What are you building?
jigsawnz
by nate21 on Sat Nov 17, 2012 10:41 pm
a egg incubator
nate21
by jigsawnz on Sat Nov 17, 2012 11:47 pm
I've a work in progress. Relays are easy to control but the problem is the amount they switch on and off. Depending on the settings, insulation of the box, air flow and heat source, this can happen several times a minute. Even if it was every minute for 21 days thats 30,2400 times its switches on and off. They contacts will wear out.
There is a PID library for arduino that you use with Mosfets. Thats what I am using now to avoid that problem.
jigsawnz
by nate21 on Sun Nov 18, 2012 12:00 am
i will try and find that information thanks
nate21
by nate21 on Sun Jan 27, 2013 6:44 pm
are you willing to share more information on your incubator
nate21
