Dimensions of Arduino Due
by maria9876 on Mon Nov 12, 2012 6:58 pm
I'm interested in the Arduino Due, but I can't find its dimensions anywhere. Does anyone know what they are? Thanks.
maria9876
Re: Dimensions of Arduino Due
by tldr on Mon Nov 12, 2012 7:42 pm
from arduino.cc
The maximum length and width of the Arduino Due PCB are 4 and 2.1 inches respectively, with the USB connectors and power jack extending beyond the former dimension. Three screw holes allow the board to be attached to a surface or case. Note that the distance between digital pins 7 and 8 is 160 mil (0.16"), not an even multiple of the 100 mil spacing of the other pins.
The Arduino Due is designed to be compatible with most shields designed for the Uno, Diecimila or Duemilanove. Digital pins 0 to 13 (and the adjacent AREF and GND pins), analog inputs 0 to 5, the power header, and "ICSP" (SPI) header are all in equivalent locations. Further the main UART (serial port) is located on the same pins (0 and 1). Please note that I2C is not located on the same pins on the Due (20 and 21) as the Duemilanove / Diecimila (analog inputs 4 and 5).
"If I had known it was harmless, I would have killed it myself." - Phillip K. Dick, A Scanner Darkly
tldr
by maria9876 on Mon Nov 12, 2012 7:49 pm
Thank you!!
maria9876
cron
