Motor shield half bridge
I just want to make sure. The motor shield in the link below supports up to 4 bi-directional motors, so it also means it supports 8 uni directional motors in half bridge mode, right. And what would the code for controlling these motors look like
- adafruit_support_bill
Re: Motor shield half bridge
The raw L293D chips could be used that way. But as the shield is designed, a single PWM signal is use for speed control on each pair of half-bridges. So both motors would have to be going the same speed.
What if I put a motor.setSpeed() command in between the commands used to control the two motors. For example:
motor.setSpeed(100);
motor.run(FORWARD);
motor.setSpeed(200);
motor.run(BACKWARD);
delay(
...blah blah blah
Would this not run the half bridge motors at different speeds
motor.run(FORWARD);
delay(
...blah blah blah
No. There is only one pin that controls the PWM signal to both halves of the bridge.
Ok thanks. I also have another question, I know it can handle 4.5V to 25V for powering the motors but what about the current, are there limits to what current it can withstand.
The basic shield will handle up to 600mA (0.6A) on each motor channel. See the FAQ for details on how to modify it to handle higher current loads: http://forums.adafruit.com/viewtopic.php?f=31&t=26873
Ok, thank you very much
