Fingerprint sensor with Arduino Mega2560
by mad76 on Sun Nov 18, 2012 5:32 pm
Hi guys,
I am wondering does anybody know if the fingerprint sensor (ID:751) works with the Arduino Mega2560. It works fine with my Arduino UNO but when i swap boards and upload the program it tells me it can't find the fingerprint sensor. any idea's ?
mad76
Re: Fingerprint sensor with Arduino Mega2560
by franklin97355 on Sun Nov 18, 2012 7:01 pm
Have you made accomidations for the difference in pin numbers?
franklin97355
by mad76 on Sun Nov 18, 2012 7:11 pm
saw the earlier posts after putting mine up. All good now :lol:
Thanks for the reply.
mad76
Re: Fingerprint sensor with Arduino Duemilanove
by shuhada natasha m on Mon Nov 19, 2012 4:02 pm
Hi may i ask how many ID can the fingerprint cater at one time?
and can it be reset?? cuz i enrol two different IDs (0 & 2) by placing my thumb twice .
It creates problem during matching. cuz sometimes it finds a match as 0 and sometimes as 2.
Btw im using arduino duemilanove =)
shuhada natasha m
by adafruit_support_bill on Tue Nov 20, 2012 6:49 am
The english version of the manual is available now here: http://www.adafruit.com/datasheets/ZFM% ... ualV15.pdf
by shuhada natasha m on Mon Dec 10, 2012 8:42 am
thanx for the manual =)
now im trying to interface the fingerprint with keypad... i wanted it to loop it and match the inserted ID with fingerprint (customKeypad == finger.fingerID) <------- i think..... but it seems there were some conflict between the fingerprint and keypad eventhough there were no errors during uploading... can somebody pls have a look at the program ive done below? i couldnt find the mistake
[Edit - moderator - please use the 'code' button when submitting code]
void loop(){
    getFingerprintIDez();
    char customKey = customKeypad.getKey();
    if (customKey){
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print(customKey);
    lcd.setCursor(0,1);
    lcd.print("Now, fingertest");
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
      break;
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
      break;
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerFastSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
  } else {
    return p;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
 if(customKey == finger.fingerID)
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Match ID #"); lcd.print(finger.fingerID);
  lcd.setCursor(0,1);
  lcd.print("Successful");
  delay(1000);
  //return finger.fingerID;
  else
    lcd.setCursor(0,0);
    lcd.print("No Match");
    lcd.setCursor(0,1);
    lcd.print("Try Again");
   // return finger.fingerID;
shuhada natasha m
by adafruit_support_bill on Mon Dec 10, 2012 9:02 am
What you posted does not compile. Post your entire sketch. (Use the 'code' button and paste your sketch between the tags)
by shuhada natasha m on Mon Dec 10, 2012 1:28 pm
heres the complete program... the numbers from keypad wouldnt appear instead the char. of lcd were juz blinking when i press the keypad... while for the thumbprint, i have actually enrolled an ID for my left thumbprint, but it didnt recognize..
#include <Keypad.h>
#include <Adafruit_Fingerprint.h>
#if ARDUINO >= 100
 #include <SoftwareSerial.h>
#else
 #include <NewSoftSerial.h>
#endif
#include <LiquidCrystal.h>
LiquidCrystal lcd(40, 42, 44, 46, 48, 50, 52);
int backLight = 13;
int getFingerprintIDez();
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(12, 13);
#else
NewSoftSerial mySerial(12, 13);
#endif
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','4','7','*'},
  {'2','5','8','0'},
  {'3','6','9','#'},
  {'A','B','C','D'}
byte rowPins[ROWS] = {31,33,35,37}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {23,25,27,29}; //connect to the column pinouts of the keypad
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
  //Serial.begin(9600);
  finger.begin(57600);
   pinMode(backLight, OUTPUT);
  digitalWrite(backLight, HIGH);
  lcd.begin(16,2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Hello enter ID");
 // pinMode(6, OUTPUT); //RED LED
 // pinMode(7, OUTPUT); //GREEN LED
 // pinMode(13,OUTPUT); //SIREN
void loop(){
  digitalWrite(6,HIGH);
  digitalWrite(13,LOW);
    if (customKey){
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
  switch (p) {
      lcd.print("Image taken");
      break;
      lcd.clear();
      lcd.print("No finger detected");
      return p;
      lcd.clear();
      lcd.print("Communication error");
      return p;
      lcd.clear();
      lcd.print("Imaging error");
      return p;
    default:
      lcd.clear();
      lcd.print("Unknown error");
      return p;
  // OK success!
  switch (p) {
      lcd.clear();
      lcd.print("Image converted");
      break;
      lcd.clear();
      lcd.print("Image too messy");
      return p;
      lcd.clear();
      return p;
      lcd.clear();
      lcd.print("Could not find fingerprint features");
      return p;
      lcd.clear();
      return p;
    default:
      lcd.clear();
      return p;
  // OK converted!
    lcd.clear();
    lcd.print("Found a print match!");
    lcd.clear();
    return p;
    lcd.clear();
    lcd.print("Did not find a match");
    return p;
  } else {
    lcd.clear();
    return p;
  // found a match!
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Found ID #"); lcd.print(finger.fingerID);
  lcd.setCursor(0,1);
  lcd.print(" with confidence of "); lcd.print(finger.confidence);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  //digitalWrite(6,LOW);   //red led off
  //digitalWrite(7,HIGH);  // green led on
  //delay(1000);
  else
    lcd.setCursor(0,0);
    lcd.print("No Match      ");
    lcd.setCursor(0,1);
   // digitalWrite(7,LOW);
    //digitalWrite(6,HIGH);
    //digitalWrite(13,HIGH);
    //delay(1000);
shuhada natasha m
by adafruit_support_bill on Mon Dec 10, 2012 1:54 pm
You are reading the keypad in two places. Remove all the modifications to getFingerprintIDez() and put all your keypad and comparison logic in loop().
by shuhada natasha m on Mon Dec 10, 2012 9:02 pm
u mean like this???
#include <Keypad.h>
#if ARDUINO >= 100
#else
#endif
int backLight = 13;
#if ARDUINO >= 100
#else
#endif
  {'1','4','7','*'},
  {'2','5','8','0'},
  {'3','6','9','#'},
  {'A','B','C','D'}
void setup(){
  lcd.begin(16,2);
  lcd.clear();
  lcd.setCursor(0,0);
void loop(){
  //getFingerprintIDez();
 // digitalWrite(6,HIGH);
  //digitalWrite(13,LOW);
    /*if (customKey){
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  //delay(1000);
  else
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    //delay(1000);
  switch (p) {
      break;
      lcd.clear();
      return p;
      lcd.clear();
      return p;
      lcd.clear();
      return p;
    default:
      lcd.clear();
      return p;
  // OK success!
  switch (p) {
      lcd.clear();
      break;
      lcd.clear();
      return p;
      lcd.clear();
      return p;
      lcd.clear();
      return p;
      lcd.clear();
      return p;
    default:
      lcd.clear();
      return p;
  // OK converted!
    lcd.clear();
    lcd.clear();
    return p;
    lcd.clear();
    return p;
  } else {
    lcd.clear();
    return p;
  // found a match!
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
shuhada natasha m
by adafruit_support_bill on Tue Dec 11, 2012 7:21 am
You still have to call getFingerprintIDez() in your loop to read the fingerprint.
by shuhada natasha m on Tue Dec 18, 2012 9:49 pm
hi i think i've got it... im trying to call the fingerprint sensor after entering password.
the problem is juz that after i break the password using * key, the sensor illuminates <1.0sec.
how do i get it illuminate in a longer time, without pressing the * button many times.
here;s my new code
#include <Password.h>
#include <Keypad.h>
#if ARDUINO >= 100
#else
#endif
Password password = Password( "C141516" );
const byte ROWS = 4; // Four rows
const byte COLS = 4; //  columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','4','7','*'},
  {'2','5','8','0'},
  {'3','6','9','#'},
  {'A','B','C','D'}
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int alarm_var = 0;
#if ARDUINO >= 100
#else
#endif
/*SETUP****************************************************************************************/
void setup()
  lcd.begin(16, 2);
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
  lcd.clear();
  lcd.print("Password:");
  pinMode(11,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(9,OUTPUT);
  //digitalWrite(11,HIGH);
void loop()
  //digitalWrite(9,LOW);
  if (digitalRead(11)==LOW)
    digitalWrite(9,HIGH);
    lcd.clear();
    lcd.print("INTRUDER!!");
    delay(1000000);
  if(alarm_var < 3)
    keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
  switch (keypad.getState()){
    case PRESSED:
   //lcd.print("");
   lcd.print(eKey);
   switch (eKey){
     case '*': checkPassword(); break;
     case '#': password.reset(); break;
     default: password.append(eKey);
void checkPassword(){
  if (password.evaluate()){
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Success!");
    lcd.setCursor(0,1);
    lcd.print("Now scan finger ");
    //delay(1000);
  else{
    alarm_var = alarm_var + 1;
   //for (i=0; i>3; i++);
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Wrong");
    if (alarm_var >= 3)
      lcd.setCursor(0,0);
      lcd.print("Wrong 3 times");
      lcd.setCursor(0,1);
      lcd.print("Alarm Activated");
      //alarm_var = 0;
    else
      delay(1000);
      lcd.clear();
      password.reset();
  uint8_t
  // found a match!
  digitalWrite(11,LOW); // switch OFF red LED
  digitalWrite(10, HIGH); //switch ON green LED
  delay(1000);
  digitalWrite(10,LOW);// switch OFF green LED
  digitalWrite(9,HIGH); // switch ON alarm
  delay(100);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("Accepted ");
  //delay(100);
shuhada natasha m
by adafruit_support_bill on Wed Dec 19, 2012 7:23 am
    while(getFingerprintIDez() == -1)
Will loop until it gets a valid fingerprint reading.
