Arduino-powered Audio Doorbell
Postby jarruda » Tue Nov 27, 2012 1:22 pm
So when I bought my house, I noticed it had probably the most boring doorbell on the planet. Then I saw the adafruit's Wave Shield and saw inspiration.
This is my first actually completed hobby electronics project, so I'm pretty proud of it, even if it's really simple.
http://youtu.be/lDCDayKyOQA
(Is it possible to embed a youtube video on these forums?)
Main Parts:
Pre-R3 Arduino Uno
Wave Shield 1.1
Velleman 3 Watt Mono Amplifier # K 8066
Power for the doorbell comes from a 16V transformer off mains power (120V). It's run through a 50V 4A bridge diode rectifier into an electrolytic cap and a ceramic cap to smooth the pulsed DC, then two diodes to drop the voltage by ~3V before powering the mono amplifier and being split off for the UNO's Vin.
The doorbell is connected like any other button, sending 5V out to the doorbell and in to a digital pin configured as an interrupt. Using a pullup resistor and pulling the pin to ground wasn't used to lower the demand on the linear regulator running on voltage that's a bit higher than I'd like. To further reduce power usage, the atmega328 is put into PWR_DOWN sleep in between doorbell rings.
Also, thanks to adafruit_support for providing help!
My next project is a little more ambitious, a thermostat that can use a wireless sensor for temperature readings.
jarruda
Re: Arduino-powered Audio Doorbell
Postby adafruit_support_bill » Tue Nov 27, 2012 1:42 pm
Sounds like a great project. But the video link isn't working.
Postby jarruda » Tue Nov 27, 2012 1:51 pm
The video page on youtube has a banner for me that says, "Sit tight! Your video edits are about 90% done. Come back to this page in a little while." Though it's still showing me an older version of the video. Is the link working for you now? Alternative: http://www.youtube.com/watch?v=lDCDayKyOQA
jarruda
Postby MattMiddleton » Thu Nov 29, 2012 11:10 am
This looks awesome! Our doorbell is not only super generic, but rather quiet (can't hear it if you're in the basement). Is your code available somewhere online?
MattMiddleton
Postby jarruda » Fri Nov 30, 2012 9:27 am
MattMiddleton wrote:Is your code available somewhere online?
It's not, but it's nothing special. It's mostly just adafruit's wave shield sample code, but here's the meat of what is specific to the doorbell:
void loop()
  dir_t dirBuf;
  FatReader file;
  root.rewind();
  while (root.readDir(dirBuf) > 0) {
    if (dirBuf.name[0] == '.')
      continue;
    if(file.open(vol, dirBuf) && !file.isDir()) {
      putstring("Enqueued ");
      printName(dirBuf);
      putstring_nl("");
      beginSleep();
      if (wave.create(file)) {
        wave.play();
        putstring("Playing...");
        while (wave.isplaying) {
          delay(100);
        putstring_nl("Done.");
      sdErrorCheck();
void beginSleep() {
  putstring_nl("Going to sleep.");
  delay(100);
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  digitalWrite(ledPin, LOW);
  // Debounce the interrupt;
  // Also allow someone holding the button to continue playing audio (skip sleep)
  while (digitalRead(intPin) == LOW) {
      PCintPort::attachInterrupt(intPin, &interruptHandler, RISING);
      sleep_cpu();
      delay(10);
  sleep_disable();
  digitalWrite(ledPin, HIGH);
In order to sleep (to lower power consumption; this project was originally going to be battery-powered), I had to use the PinChangeInt library in order to wake the Arduino since the external interrupt pins were in use by the wave shield.
Sidenote to adafruit_support:
It'd be nice if this forum allowed embedding of youtube videos or had a plugin to do syntax coloring on posted code. :)
jarruda
Postby sarahline » Sun Mar 03, 2013 6:20 pm
Is there a chance you could post all of your code? I am trying to figure out how to put my Arduino to sleep after it plays a sound that is triggered by a button.
sarahline
Postby jarruda » Tue Mar 05, 2013 10:49 am
Hi sarahline,
Sure! http://pastebin.com/wbNiaQ1H
I'm not 100% positive this is the last revision of the code, but glancing over it, it appears to be what I have running on the device. Hope this helps.
jarruda
Return to Arduino
Users browsing this forum: No registered users and 9 guests
New Products [114]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
