Menta with FTDI Friend
by asgard on Wed Nov 28, 2012 5:05 pm
I recently constructed a Menta board, which worked (for a while). For some reason, recently, the FTDI friend seems to not like to talk to the Menta board, even though I know the bootloader is functioning (the LED is doing its blinky thing). I did have a custom shield connected while I was programming the MCU, so I was wondering if anybody else have observed the Menta appearing to be (mostly) bricked because of a bunch of LED's drawing power from the shield connectors while the FTDI friend is trying to talk. Maybe it is the FTDI friend that is bricked. The avrdude error code is the infamous 500 code (not in sync). Is there a maximum current draw while downloading the sketch which does something (wonderful/unexpected) with the fuses etc? Is the situation recoverable or do I start from scratch?
J.R.
asgard
Re: Menta with FTDI Friend
by adafruit_support_bill on Thu Nov 29, 2012 6:56 am
How many leds and how do you have them connected? Do you have current limiting resistors on leds driven from Menta pins?
If you post clear photos of your setup it will give us a better idea of where the problem might be.
by asgard on Thu Nov 29, 2012 5:50 pm
Well, here is the schematic of the shield, fyi:
[img]<img%20src="http://farm9.staticflickr.com/8482/8231097104_64a199c082.jpg">[/img]
And here is what the board looks like:
[img]<img%20src="http://farm9.staticflickr.com/8337/8230033759_1493be348e.jpg">[/img]
asgard
by asgard on Thu Nov 29, 2012 7:13 pm
Probably bad form to follow up my own post, but it is what it is. The transistors are 2N3904's.
J.R.
Project layout - P01-105 LEDSenShield
Project schematic - P01-105 LEDSenShield
asgard
by adafruit_support_bill on Fri Nov 30, 2012 7:29 am
You are driving leds with the Rx/Tx pins (D0/D1). These are the pins used by FTDI for communication.
by asgard on Sat Dec 01, 2012 4:09 pm
Fair enough, I suppose. The FTDI Friend is no longer talking to the Menta now, even with the custom shield removed.
J.R.
asgard
by adafruit_support_bill on Sun Dec 02, 2012 9:32 am
Do you see any led activity during the upload attempt?
Double-check your board-type and COM port selections (should be Duemilanove w/328)
