Fingerprint Sensor with Arduino Mega 2560/Duemilanove
by CelsoPadilha on Thu Nov 29, 2012 9:23 pm
Hello guys, my fingerprint sensor doesnt show life signal, just blink, I recorded one video to show how is happening.
I've read another topics saying about this problem, my cables are perfect, the ports are ok, I dont understand what the fingerprint sensor doesnt work. I need some help guys.
Someone has the same problem?
Cables:
Red = 5V
Black = GND
White = 3
Green = 4
The vídeo (The quality is sux but is possible to see) :
http://www.youtube.com/watch?v=L5g2-B19iu4&feature=plcp
CelsoPadilha
Re: Fingerprint Sensor with Arduino Mega 2560/Duemilanove
by adafruit_support_bill on Fri Nov 30, 2012 7:24 am
For some reason I can't play the video. Can you post a still photo showing your connections?
by CelsoPadilha on Fri Nov 30, 2012 9:24 am
I Can't post the photo now, because i'm working, but the wires conected are:
Red Wire = 5V on Arduino
Black Wire = GND on Arduino
White Wire = Digital port 3 on Arduino
Green Wire = Digital port 4 on Arduino
CelsoPadilha
by CelsoPadilha on Fri Nov 30, 2012 9:35 am
The same problem is happening in Arduino Mega 2560, the Arduino 2560 and Arduino Duemilanove works great, but when I connect the fingerprint sensor happen just one blink.
CelsoPadilha
by adafruit_support_bill on Fri Nov 30, 2012 9:48 am
Are you connecting via a breadboard or direct to the Arduino headers?
Did you solder any connectors or pins to the ends of the sensor wires?
by CelsoPadilha on Fri Nov 30, 2012 1:59 pm
I'm connecting direct to the Arduino.
Yes i'm did solder in all four conectors, and I tested all four with a multimeter and its all ok.
Today I'll post a picture.
CelsoPadilha
by CelsoPadilha on Sat Dec 01, 2012 9:15 am
The photos:
CelsoPadilha
by adafruit_support_rick on Sat Dec 01, 2012 1:55 pm
The example sketch expects Green on pin 2 and White on pin 3. Have you modified the sketch? Looks like you're using pins 3 and 5 in the photos.
by CelsoPadilha on Sat Dec 01, 2012 5:16 pm
I changed to take a picture, this way of wiring happens the same problem.
CelsoPadilha
by adafruit_support_rick on Sat Dec 01, 2012 8:15 pm
In that case, have you tried swapping white and green?
by CelsoPadilha on Sat Dec 01, 2012 9:21 pm
Yes, the problem still happening
CelsoPadilha
by adafruit_support_rick on Sat Dec 01, 2012 10:19 pm
The sensor won't light up unless it's actively scanning a fingerprint. What sketch have you loaded?
Also, the tutorial takes you through a setup process with Windows prior to attaching the sensor to an arduino.
Have you gone through that process? Did the sensor work then?
by CelsoPadilha on Fri Dec 07, 2012 1:45 pm
Sry for the time to answer the question.
I try the tutorial and the problem was different. The problem are in the image:
I've seen other topics for this problem but, no one of this topics on adafruit forum doesnt work to me.
The COM Port are Ok and is the sensor port.
What I do?
CelsoPadilha
by adafruit_support_rick on Sat Dec 08, 2012 12:05 pm
Please contact support@adafruit.com for a replacement. Reference this thread and include your original order number.
cron
